BikeBandit
Old 11-13-2006   #1 (permalink)
blk
Favorite Bike: LC 350
Just fitted some TORs on my 06 S3 today
But one of them doesnt seem to fit as far as the other into the main pipe by the heel guard.(rear of silencer is touching the indicator) :???:
It is stopped by the Main bolt holding the can onto the frame above the rear footrest hanger.
Ive noticed the bracket on the race can has a drilled hole on the fitting bracket, as apposed to the standard can which has a slotted hole, which allows for more flexibility in fitting.
I,m looking at modifying the hole on the race can to allow it to push further onto the main pipe.
Is this normal??? :???:
[ This message was edited by: blk on 2006-11-13 08:50 ]
http://i114.photobucket.com/albums/n...sidogWinCE.jpg
If i throw you a stick, will you go away??
blk is offline   Reply With Quote
Old 11-13-2006   #2 (permalink)
Mine fit fine. They didn't slide in as far as the stockers, but they fit just right. Check that there isn't anything binding up in the coupling at the mid pipe.
TOR's with tune
Renthal Streetfighters
Rizoma bar ends and mirror
Custom aluminum fenderectomy
speedydave is offline   Reply With Quote
Old 11-13-2006   #3 (permalink)
blk
Hi Speedydave
There doesnt seem to be anything catching the silencer.
It just seems to be held at that position by the main bolt :???:
I,ll let the dealer have a quick look, when he puts the remap on.
Worst case scenario, i make the hole slightly elongated by a couple of mill on the can bracket. Dont want the indicator turning into mush
Old 11-13-2006   #4 (permalink)
BLK,
I have to modify the holes in mine too.. I took a dremel tool too it and enlogated the hole. They see to fit better now
huff955 is offline   Reply With Quote
Old 11-13-2006   #5 (permalink)
blk
Its seems a bit strange that the standard cans have elongated holes, but the race cans dont.
I think i,ll probably go the dremel route :hammer:
Old 11-13-2006   #6 (permalink)
My TORS had the same problem. Hole needed elongating, which I never got round to doing, 'cause I got a Zard instead.
Avi8or is offline   Reply With Quote
Old 11-13-2006   #7 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS
Extra Motorcycle: TT600 - Spongebob
C'mon over the pond. We'll make it fit :-D
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 11-13-2006   #8 (permalink)
blk
Give me 5 mins, I,m on my way :brk:
Old 11-13-2006   #9 (permalink)
Limited Access
203MPH is offline   Reply With Quote
Old 11-13-2006   #10 (permalink)
same problem here. sucks. had to dremel it.
tekmoe is offline   Reply With Quote
dont know if you guys have seen this doodledog Daytona Deliberations 1 01-19-2008 05:37 PM
Clutch Arm lifter Bellows dont fit UK Davesky Twins Technical Talk 2 11-18-2007 08:42 PM
I dont believe it!!! Bundyon_Jen Biker Hang-Out 16 04-25-2007 08:06 PM
Trying to register, but dont seem to fit in anywhere. SFCMarkC General RAT Discussion Forum 1 12-28-2005 08:10 PM
Dont Miss This shortys Classic, Vintage & Veteran 1 10-18-2005 02:25 PM
