BikeBandit
Old 11-11-2006   #1 (permalink)
I am trying to find out why my bike is stumbling......www.triumphrat.net/modules.php?op=modload&name=Forum&file=viewtopic&t opic=64179&forum=19
I went to take my tank off and discovered that the breather tube with PCV MAY not have been attached. It is attached at the cannister, but I really dont think the other end was attached to anything.
There are 2 nipples on the tank. One is hooked up, and the inner one had nothing on it. It appears as though the PCV should go there, but that doesn't make sense to me.
I REALLY need a assembly manual picture of the tank..
Can anyone help me out?
jh225 is offline   Reply With Quote
Old 11-11-2006   #2 (permalink)
blk
Favorite Bike: LC 350
Hope this helps
http://i114.photobucket.com/albums/n...sidogWinCE.jpg
If i throw you a stick, will you go away??
blk is offline   Reply With Quote
Old 11-11-2006   #3 (permalink)
That is the overflow for the tank. Not having it hooked up wont make the bike stumble.
Just livin' the dream.
Tee-Dub is offline   Reply With Quote
Old 11-11-2006   #4 (permalink)
Both those lines are vent lines- one for the tank and one for the fuel overflow. The bike will run fine with both removed and many have done so. The problem comes when they get reversed. There is a one way valve on one, and when it gets on the wrong nipple it causes tank vacuum. This can cause all sorts of hassle.
Neither of these lines goes the the PCV valve, so don't worry.
crashmasterd is offline   Reply With Quote
Old 11-11-2006   #5 (permalink)
Yup, called a dealer and he explained that it is actually a check valve, and yes it does hook to the tank.
It will also NOT make the bike stumble if disconnected.
I pulled the plugs and they were toast. Guy probably just started the bike and let it idle a few minutes at a time for the last year or so.
Old 11-13-2006   #6 (permalink)
If you ever get a vacuum developing in the tank (and that will make the bike stumble a little) then just pop the valve off the bottom of the breather tube and give it a good shake or flush with solvent to get the valve free again.
I'm as pure as the driven slush - As Jeffrey Dahmer should have quoted... "It's not the skinning that counts, it's the taking apart!"
Scarpa is offline   Reply With Quote
Oil from Tank Breather speede Sprint Forum 2 08-13-2007 11:44 PM
Tube breather seepage chieffieldeng Twins Technical Talk 3 08-06-2007 09:11 PM
Can't find Airbox breather tube?!? Jack_T_Bird Hinckley Classic Triples 7 04-19-2007 04:43 PM
You're supposed to put gasoline in the tank??? Chris3D Speed Triple Forum 4 03-25-2007 06:07 AM
Fuel tank breather hoses? fryingtonite Speed Triple Forum 11 12-05-2006 05:06 PM
