Old 11-05-2006   #1 (permalink)
Chaps,
My garage has a habit of leaking after a very heavy downpour which leaves a damp floor for a day or so. Are there any areas of the 06 S3 that I need to keep an eye on in turns of corrosion. I also happen to live right by the sea which doesn't help
ExPatTommo is offline   Reply With Quote
Old 11-05-2006   #2 (permalink)
A dehumidifier should help.
Avi8or is offline   Reply With Quote
Old 11-05-2006   #3 (permalink)
I live next to the sea also, The only corrosion I have found has been in the spark plug holes.
Either from washing or riding in heavy rain.
Someone has written in that they found corrosion on the top of the rear shock, I don't have that problem.
I put a coating of Corrosion-X In the plug holes and it seems to have it under control.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 11-05-2006   #4 (permalink)
Skip the next set of mods and fix your garage.
And you KNOW this.........MAAANNN.
itchin is offline   Reply With Quote
Old 11-05-2006   #5 (permalink)
I would but unfortunatley I rent the apartment and the building owners have already tried to fix it. Something to do with the lie of the land and an overflowing drain system when we have a downpour
Old 11-05-2006   #6 (permalink)
Sorry, thought you were the owner.
Old 11-06-2006   #7 (permalink)
Mine was one of the very first customer bikes delivered March 05 and I have to say she still lokks very good. No rust concerns. The bolt heads still look the biz too.
When she was new I bought Scottoiler 365 spray (in a yellow bottle) and it has really helped in keep the thing clean and easy to clean.
http://www.scottoiler.com/pc/Categor...Sort=19&page=2
MH
If it looks like an Aligator,
Walks like an Aligator
and
Bites like an Aligator.
It could be a Crocodile......
MonkeyHanger is offline   Reply With Quote
Old 11-06-2006   #8 (permalink)
Favorite Bike: Speed3 -09
Same here. Ridden in all kinds of weather from April '05 onwards and stored under a roof in a carport.
No rust to be found anywhere (except the plugs of course). No pitting on the exhaust. Bolts look good. Brake line banjos look good. Rear shock is uncorroded and plating intact. All the usual first suspects are OK.
:upthumb:
Martin_R is online now   Reply With Quote
Old 11-06-2006   #9 (permalink)
I'm keeping her clean with WD40 which should help to reduce any possible corrosion
Rust Nzbiker Twins Technical Talk 4 11-26-2007 07:53 AM
Rust Nzbiker Twins Technical Talk 3 09-02-2007 10:17 AM
Rust staxx Twins Technical Talk 7 03-01-2007 04:36 PM
Rust TonyH Triumph SuperSports 4 05-06-2006 10:07 AM
RUST! Gene-O Twins Talk 13 05-05-2006 04:51 PM
