I just put a new one in my bike. If you get a new one make sure it gets a nice full charge at about one amp. Some shops want to hurry the job and give it a higher charge over a shorter period of time. I have even taken batteries home and then charged then myself. The charging directions should be with the bat. or on it. A easy way to get the battery in or out is to use the plastic clothes line and run it through the battery post. You can then make a handle to pull the battery out and use it to drop the new one in.
[ This message was edited by: TRISPEED on 2004-08-09 12:34 ]
