Old 10-30-2006   #1 (permalink)
Being plastic, can you still T-cut it? :???:
Tricks is offline   Reply With Quote
Old 10-30-2006   #2 (permalink)
Limited Access
yup, but I think T-cut is a little harsh.
Limey is offline   Reply With Quote
Old 10-30-2006   #3 (permalink)
Ok, i'll bite........... What's T-cut?
TOR's with tune
Renthal Streetfighters
Rizoma bar ends and mirror
Custom aluminum fenderectomy
speedydave is offline   Reply With Quote
Old 10-30-2006   #4 (permalink)
Limited Access
Its a cutting polish, I would only use it on really dull paint. I've never seen it in the USA.
[ This message was edited by: Limey on 2006-10-30 15:24 ]
Old 10-30-2006   #5 (permalink)
DarkSkies's Avatar
T-Cut helps to easily remove surface oxidation, blemishes and mild scratches easily restoring the lustrous colour of your car in minutes.
Apparently.
"I have only five words for you: From my cold, dead hands."
DarkSkies is offline   Reply With Quote
Old 10-31-2006   #6 (permalink)
Apparently.
You don't work for T-cut do you Darkskies,that sounds just like a commercial. :hammer:
Bucket
BUCKET is offline   Reply With Quote
Old 10-31-2006   #7 (permalink)
Try Meguiars "Scratch X". this stuff is brilliant, but it is not as harsh on the paint work as a cutting polish would be.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 10-31-2006   #8 (permalink)
Used it for years on metal but wondered if it would be to harsh on plastic...
Old 10-31-2006   #9 (permalink)
I would not use it to refresh the knee cutouts as the scratches will be back in 15 minutes and you would have to grind layers of lacquer/paint off every week if you wanted to keep the tank in good shape.
And how many rubbing compound uses does it take until the undercoat will start shining through?
Maybe I would use it once before selling the bike, but not more often.
[ This message was edited by: Martin_R on 2006-10-31 05:20 ]
Martin_R is offline   Reply With Quote
Old 10-31-2006   #10 (permalink)
DarkSkies's Avatar
[quote]
No, I lifted it from the splurge on one of their retailer's sites.
Black knurled plastic knob L/H side of carb? barneys Twins Technical Talk 10 08-24-2007 07:39 PM
Wanna trade your black tank for my red and black T100 tank? Billdozer Twins Technical Talk 12 06-04-2007 12:49 PM
cleaning black plastic parts on the Trophy garyn Trophy 2 04-25-2007 04:48 PM
Black Plastic Plugs in Dash Bezel kcnlisa Twins Technical Talk 4 06-29-2006 07:20 AM
what is the black plastic strip on the screen for? rstrophyman Trophy 7 08-23-2005 06:08 PM
