» Links |
10-11-2006
Does anyone know the specs for "chain slack"? and where do you measure?
Check the manual - it has specifics on the measurements and measuring. Note: you may need to adjust for more slack if you wiegh more than the average rider. I am around 230 and need to give a bit more play.
Good luck.
10-11-2006
Previous owner lost the manual, thanks though.
10-11-2006
Limited Access
35-40mm play measured from the tightest point on the chain. If you have a rear stand rotate the wheel until you find the tightest part of the chain, if not push it back an forth til u find it. Get a tape measure. from the bottom of the chain 0 mm push up, the top of the chain is the measure point, 35-40mm. Hope that made some sense.
10-11-2006
After doing all that, sit on the bike and check that the chain still has a bit of slack in it
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
10-12-2006
Triumph specifies checking the slack on the side stand not on a center stand. You will have more slack on a center stand and if you adjust to 35-40 it will be too tight when the suspension is compressed. Weight does not make any difference as the chain needs to be loose enough to account for the complete suspension travel no matter what you weigh.
10-16-2006
Thanks, i've been out of town, but will be putting your ingo to good use this weekend.
10-16-2006
Make sure to roll your bike forwards and backwards before checking, because it can slaken after being being rolled backwards.
Brakes are for people who ride slow.
10-16-2006
World SuperBike Favorite Bike: '71 Honda 70
On 2006-10-11 21:51, Limey wrote:
... from the bottom of the chain 0 mm push up, the top of the chain is the measure point, 35-40mm. Hope that made some sense.
Hold on a sec. Are you saying it should be measured from the bottom to the top? Not the bottom to the bottom (or the top to the top)? I need to know as I am out of adjustment otherwise?
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
10-16-2006
That's what I got out of it
