Explain computer reflashes and tunes to me..... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleSportbikeTrackGear
Old 10-04-2006, 03:28 PM   #1 (permalink)
I have been reading about new exhausts and most people who get an exhaust get a tune for it.
Now I understand reflashing the ECU and what the tunes do, so here is my question.....
I'm not talking about a tuneboy or Power Commander, just the OEM unit.
How many tunes can the ECU store? How are they accessed?
Who can do the reflash?
Suppose I bought a set of TOR's and wanted to get the TOR tune. What would be the procedure to get it?
Will it be erased if the battery dies?
How much does it cost?
Sorry for the newbie questions!!!!!
speedydave is offline   Reply With Quote
Old 10-04-2006, 04:01 PM   #2 (permalink)
The ECU can store only one flashed tune at a time.
Reflashing the ECU requires a programmer (a dealer only part), or Tuneboy.
To get the TOR tune, take your bike to a dealer and have it done. They normally charge for 1/2 hour of work (some more, some less). If you buy the TOR silencers through your dealer, generally the tune comes with the price of the silencers.
The tune is stored on a chip in the ECU. It will not be lost if the battery dies, but just like the stock tune, it can become corrupted (although rare).
Reinstated
Devious2XS is offline   Reply With Quote
Old 10-04-2006, 04:09 PM   #3 (permalink)
Favourite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Whew! Y'know, I was just wonderin' about just such a thing, on accounta I got the TORS tune before the wires went all goofy an' blew the fuses. I figured it was stored on some kinda flash memory gizmo and would not default back to stock when the battery was disconnected, but I hate to assume.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 10-04-2006, 07:15 PM   #4 (permalink)
Been ogling the BikeBandito site. Seems if you're rich enough you SHOULD be able to order the programmer.
iconTriumph Tools
Avi8or is offline   Reply With Quote
Old 10-04-2006, 07:35 PM   #5 (permalink)
Makes Tuneboy look like quite a bargain.
dr_gallup is offline   Reply With Quote
Old 10-05-2006, 07:28 AM   #6 (permalink)
thanks for the info!
So if someone has a tuneboy with the triumph adaptor and software, they could flash my bike and I would be set?
Old 10-05-2006, 07:38 AM   #7 (permalink)
To use the dealer programmer, you also need to be able to access and download the Triumph tunes into it.
Speedydave - You will need to buy a Tuneboy key for your ECU - USD $150. Your friend (with the Tuneboy cable) connects to your bike and downloads the ECU serial number and you send it in an e-mail to Tuneboy.com.au and pay for the key - they will e-mail the key to you. I did this for HiVel, and now he is considering buying his own Tuneboy cable (a simple upgrade if you already have bought the key).
Reinstated
Old 10-05-2006, 08:51 AM   #8 (permalink)
Ok, so if I pick up a used set of TOR's or whatever, I will need to go to a triumph dealer and get a reflash.
And they will charge me about .5 hour of their labor rate.
Thanks!
Old 10-05-2006, 09:11 AM   #9 (permalink)
Most shops will charge around USD $50 for the flash to TOR tune - IF you buy the TOR silencers elsewhere. This will bump your power about 4-5 hp (4.5%) - including the silencers.
A tuneboy key will cost $150, and using Wayne MacDonald's dyno-tuned map, you can get an additional 5-6 hp (5-5.5%) - and a much wider powerband. For the additional $100, and a friend with Tuneboy, this is the best bang for your buck. The hard part is finding someone in your area with Tuneboy.
Just my .02
Reinstated
Old 10-05-2006, 01:03 PM   #10 (permalink)
Just for general BS knowledge (that doesn't do you any good), The term "flashing" the ECU comes from past EPROM chips that required exposing the chip to UV light to actually alter its programming.
Now "flashing" is just a term for reprogramming the chip.
I TOLD you it wouldn't do you any good!
Reinstated
Can someone explain this? HiDesert Biker Hang-Out 13 03-10-2007 05:33 PM
Would Someone please explain... ASHE52 Sprint Forum 9 03-04-2007 10:47 PM
Can someone please explain HiDesert Biker Hang-Out 2 01-31-2007 04:14 AM
I need someone to explain SCCTrim Twins Talk 3 10-11-2006 06:52 PM
Can someone explain this to me??? fivehundo Daytona Deliberations 7 08-12-2006 06:46 AM
