25-cent zip tie killed my $9999 Triple - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old 10-03-2006, 12:04 PM   #1 (permalink)
Favourite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
So, me an' Gimpy The Redhead took the bonnie in to get an estimate (thing rides great, and I actually prefer the "custom" bend on the left side of the bar to the stock bend of the right). Went in back to visit der speedy with the service manager.
There's a perfect stripe of bare wire right where someone, during assembly, pulled a zip tie too tight, binding the wires and causing the insulation to rub through.
He said they had the same problem with a Vespa scooter where the wires were secured with a zip tie.
So... ya might wanna check the zippies on yer trippies.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 10-03-2006, 12:47 PM   #2 (permalink)
Was it the tie right at the ignition cylinder? I was thinking that one looked really tight on mine. I have overtightened them myself and caused problems before, so I always tend to eyeball them.
Motorsickle spoken here.
milqster is offline   Reply With Quote
Old 10-03-2006, 12:50 PM   #3 (permalink)
R100Pilot's Avatar
That would be the one.
Really cleaned the wires off good. I'll get a pitcher of it if they still have it layin' around when I go back.
— HST
Old 10-03-2006, 12:58 PM   #4 (permalink)
Bloody 'ell...it's always the little things. Good to hear they've found the problem, and that it is a simple one that shouldn't keep you from your Speedy for much longer. You had the rest of us pretty worried there!
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 10-03-2006, 01:01 PM   #5 (permalink)
Many of the zipties on my S3 have been replaced. I wasn't impressed with the way they were routed. It doesn't surprize me that this could cause an issue.
Reinstated
Devious2XS is offline   Reply With Quote
Old 10-03-2006, 01:22 PM   #6 (permalink)
Favourite Bike: '71 Honda 70
Goffe's Avatar
I just noticed a crack in the sheathing near the zip tie at a kink. Why does Triumph do a 180 with the wiring as it leaves the ignition cylinder? Just to secure it with a zip tie? What should I do about the crack? Wrap some electrical tape around it?
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
Old 10-03-2006, 01:45 PM   #7 (permalink)
Favourite Bike: 06 Speed Triple
Joemomma's Avatar
Other Motorcycle: 99 SV 650
Extra Motorcycle: 03 WR250F
FWIW, I always use friction tape in place of zip-ties on my dirt bikes, & have taken to using it when building gear racks that are used on the road ( I still use zip-ties for installs that don't move). It doesn't gum up like e-tape, is easy to remove in case of repair or modification, & it won't rub through the wire harness.
I consider it a cross-polination of vocation/advocation.
insert clever saying here...
Joemomma is offline   Reply With Quote
Zip mount for tailbag skuuter Speed Triple Forum 4 01-23-2008 07:03 PM
Zip ties save the day! ThruxACT Club Cafe' 2 12-18-2007 12:14 PM
Where to Dyno in cent. Pa.? EDC64 Maintenance & Workshop Talk 1 09-15-2007 11:22 AM
Spoet Touring section getting killed by the Speed Triple section triumphite Sprint Forum 26 06-09-2007 10:03 PM
