Rizoma rear set setup - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-03-2006, 08:27 AM   #1 (permalink)
I've been using Rizoma rear sets for a while now. They're cool, but the problem is that the rear brake barely works anymore. I need to push the lever deep to make it brake and it's impossible to get the rear tyre to lock. I think the problem is that the brake lever doesn't push the master cylinder deep enough with the normal range of motion, just not enough leverage.
Has anyone noticed this too? Any bright ideas how to make it work?
The rear sets are a bit too high up for my taste. They're mounted on the lowest possible position. Is there easy way to drop them lower than the standard mounts?
premier is offline   Reply With Quote
Old 10-03-2006, 08:30 AM   #2 (permalink)
Had you tried adjusting the length of the master cylinder push rod. undo the lock nut and it adjusts up and down. Just don't make it bind. :???:
Sarcasm. Is just one more free service I offer.
Limey is offline   Reply With Quote
Rear Set smwoods Sprint Forum 1 10-29-2007 05:29 AM
Rear Spring Setup RS.Fez Speed Triple Forum 4 08-30-2007 12:57 AM
Rizoma Rear set control kit Fenster Speed Triple Forum 8 05-29-2007 02:20 AM
N.H. GIVI setup & also a new rear rack pbpeel Twins Technical Talk 1 07-07-2006 07:30 PM
head set communication setup rusty The Rocket Science Forum 2 06-04-2006 10:07 PM
