AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 09-27-2006   #1 (permalink)
crabs
The overheat light on my bike keeps coming on, but just barely. When the sun is out you can barely see the light come on, and it never comes on all the way. I checked the coolant level and even the crankcase oil, jiggled the wire leads going into the radiator and it still comes on just a little bit.
My first thought is that I should change the thermostat, but first I wanted to find out if other people with 885 triples had run into this and found out something else was causing it.
Also, the light seems to come on at speed, and it fades completely out at idle, which is the reverse of what you would normally expect if the thermostat needs to be replaced.
Any help with this would be most appreciated.
Old 09-27-2006   #2 (permalink)
Sorry, I've never even seen the overheat light.
StoneTriple is offline   Reply With Quote
Old 09-27-2006   #3 (permalink)
These bikes are known to occasionally have a bad temperature sensor. I'd check that first.
crashmasterd is offline   Reply With Quote
Old 09-27-2006   #4 (permalink)
crabs
thanks for the tip, I'll check that out.
Old 09-27-2006   #5 (permalink)
i'd be interested in hearing about this. i've been dealing with the exact same issue on a 95 triple... :???:
[ This message was edited by: bfishman on 2006-09-27 19:55 ]
bfishma
bfishman is offline   Reply With Quote
Old 09-28-2006   #6 (permalink)
Favorite Bike: 1995 Triumph Speed Triple
Never any problems here...
Where's the smart people with all the mechanical problems on this??
Travis
Albany, NY
tealetm is offline   Reply With Quote
Old 09-28-2006   #7 (permalink)
Sounds like the temp sensor is going bad. Remember all these do is reduce resistance to ground , the higher the temp the lower the resistance the brighter the bulb , BUT at speed you have a higher volatge on the battery and if the sensors resistance is a tad low with higher battery voltage the bulb may glow a little but at idle the lower volatge may not make the bulb glow.
rckrzy1 is offline   Reply With Quote
'95 Speed Triple Overheat light DPFan Modifications & Workshop Talk 3 05-07-2007 08:59 PM
Is my fuel light coming on too soon???? Skiandclimb Daytona Deliberations 10 06-15-2006 06:27 AM
Speed Triple's mesh: gold, silver, black, dark silver (photo) marcomanila2 Speed Triple Forum 2 05-12-2006 07:35 PM
temperature light coming on JohnRimmer Hinckley Classic Triples 2 06-24-2005 08:25 AM
Overheat light comes on with flashers Fozzy Hinckley Classic Triples 1 09-14-2004 04:45 PM
