Old 09-23-2006   #1 (permalink)
I would like a little bit better acceleration so I have been thinking about changing one of the sprockets. What are the recommendations on the 1999-01 S3s? Should I go down one in the front or up a couple in the rear? Any woes I should be aware of?
Thanks all!!!
fernman is offline   Reply With Quote
Old 09-23-2006   #2 (permalink)
Generally, going up two in the rear presents fewer clearance issues that going down one in the front. A number of folks have mentioned that the gearing ratios are about the same either way.
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 09-23-2006   #3 (permalink)
Favorite Bike: '01 Speed Triple
When I replaced my sprockets, I went with a 45 T in the rear, and an 18 T counter, with an 110 link chain, so I would have room to put on the 19 T counter for high speed cruising. I put the 19 T on ,and haven't put the 18 back on once. Going up on the rear will also extend your chain life.
Speed3 is offline   Reply With Quote
Old 09-23-2006   #4 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
I would go 2 to 3 teeth more in the rear and see how you like it. Your bike speedo is driven by the front wheel right? So no need for speedo calibration.
PM me your email and I will send you and EXCEL spreadsheet for calculationg gear ratios and speed.
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 09-24-2006   #5 (permalink)
what is the down side of going down one on the front?
Old 09-24-2006   #6 (permalink)
Small front sprockets wrap the chain around a smaller radius and cause greater angular movement & velocity on each link pin. Shorter chain life. That said, it is common to run dirt bikes as low as 13 teeth.
dr_gallup is offline   Reply With Quote
Old 09-25-2006   #7 (permalink)
That being said...the stock 18t is unusually tall. My previous street bikes had 16t fronts
Old 09-26-2006   #8 (permalink)
I have 45T rear and like it, but never rode it stock so I have nothing to compare it to. Still turns at a pretty lazy rpm in 6th on the highway.
wannabes3 is offline   Reply With Quote
Old 09-26-2006   #9 (permalink)
What is the stock rear? 42t or 43t?
Old 09-26-2006   #10 (permalink)
It should be stamped on the side of the sprocket. My '01 oem is 43 teeth.
front sprocket change. Ski_rat Club Cafe 12 09-10-2007 08:10 AM
gearing and tyre change Qual Speed Triple Forum 6 03-14-2006 10:21 PM
Sppedometer error with gearing change? DanPtWash Speed Triple Forum 8 02-13-2006 12:52 PM
Change S3 gearing; any recommendations? carbster09 Speed Triple Forum 8 01-05-2005 11:39 PM
Front sprocket gearing change Netmaker Trophy 5 05-29-2004 07:21 AM
