Old 09-14-2006   #1 (permalink)
Hello people with Speed Triples.
I own a Speed Four...No wait, please hear me out..
I have bought some of those lovely sporty looking Pazzo's courtesy of MOTO WORLD ONLINE (Thank you FalcoLion) and was surprised at how easy they were to fit...at first. Got the brake lever on, no problem, and my new found confidence at mechanical modification reached an all time high. Spent a bit longer fitting the clutch. Lots of pulling and pinched fingers until I unattached the cable at the engine end, and then on it went, and lovely it did look. But... I didn't realise I had to fit a 'bush' into the hole in the lever for the pivot bolt to sit in (although on reading the fitting instructions properly this info was indeed included). Did anyone who has pazzo's get this part with their levers, if not from where did you purchase it, if indeed you needed one for the bigger bikes you own. I tried removing the one in my std lever but to no avail. I have phoned my dealer but there is no seperate part available.
Any help appreciated
Cheers
Eeyun
johnny5 is offline   Reply With Quote
Old 09-14-2006   #2 (permalink)
The bushing is on the stock levers - just remove it and install on the Pazzos. At least it is on the stock Triple levers. Contact a parts breaker and get ones from a Triple or Daytona if your stock ones are not correct. They can't cost much.
I hope this helps.
[ This message was edited by: Devious2XS on 2006-09-14 04:17 ]
Reinstated
Devious2XS is offline   Reply With Quote
Old 09-14-2006   #3 (permalink)
Cheers Devious,
In that case I shall have to buy a correctly sized punch and do it properly.
Eeyun
Old 09-14-2006   #4 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Yep - the bushing (as noted in the instructions) slid right out of my stock clutch lever and into the Pazzo lever.
Side note: Forgetting the Golden Rule ("READ THE INSTRUCTIONS"), I just unbolted the old clutch lever and then went through much wrangling and consternation getting the cable out of the old lever and into the new, in the process fraying one of the precious strands of cable.
The instructions (in the Super Secret PDF Technical Manual) clearly state that you should undo the cable at the transmission end first.
DUH :hammer:
New cable on the way.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 09-14-2006   #5 (permalink)
yep, what devious and r100 said is true.
05 Speed Triple
jdub3 is offline   Reply With Quote
Old 09-14-2006   #6 (permalink)
I didn't really have any trouble with my cable, and I didn't undo it at the transmission.
I removed the pivot bolt, then pulled the lever to where the cable was stright with the exit slot on the lever (like we all did).
Then I pulled it to release it from the adjusting nut slot. I did have to turn my adjustment nut a slight bit to get the exit groove lined up with the mount.
It came out pretty easy after that.
DwarF is offline   Reply With Quote
Old 09-14-2006   #7 (permalink)
I had no problem with my Cables either.... I did forget the bushing and had to take it apart and install it once I notice the play in the lever.
xSpeed3x is offline   Reply With Quote
Pazzo's Hedge Twins Technical Talk 27 10-22-2007 09:26 AM
Get PAZZO's dblhelx Speed Triple Forum 21 09-05-2007 10:57 AM
People with Pazzo's post up......... speedydave Speed Triple Forum 26 02-05-2007 03:08 PM
People with Pazzo's johnny5 Triumph SuperSports 10 10-13-2006 02:05 AM
Pazzo's are snazzo mouse Sprint Forum 4 06-06-2006 08:14 PM
