BikeBandit
Old 09-12-2006   #1 (permalink)
DarkSkies's Avatar
About six months back, using good quality hydraulic fluid, I bled my brakes - as so many people had recommended - given their notoriety. I got a few bubbles out but nothing to write home about.
Six months later, lever to the bars easily, but no discernible loss in performance during riding - I re-bled them.
I was astonished at just how much air was in the system (front). Not just a little more than you'd have liked but LOTS as in, at one point, I thought a seal had gone somewhere because I'd already got through half a bottle of fluid. Eventually, after the best part of 500 ml, the last bubble was removed. Lever is firm and braking noticeably firmer.
Anyone else found such a dramatic amount of air in such a short space of time?
"I have only five words for you: From my cold, dead hands."
DarkSkies is offline   Reply With Quote
Old 09-12-2006   #2 (permalink)
Limited Access
All the time. when the pliers on the pads trick stops working its time to bleed.
Limey is offline   Reply With Quote
Old 09-12-2006   #3 (permalink)
DarkSkies's Avatar
That's cr&p! My old Z1000 could go two years without bleeding - and then only tu put new fluid through the system.
[ This message was edited by: DarkSkies on 2006-09-12 13:50 ]
Old 09-12-2006   #4 (permalink)
5/8 master and twin lines. Still going stiff after 2 months...........
Avi8or is offline   Reply With Quote
Old 09-12-2006   #5 (permalink)
Limited Access
I'd see a doctor about that, mate!
Old 09-12-2006   #6 (permalink)
I thought you needed to call the doctor if it stayed stiff over 4 hours :-D
[ This message was edited by: speedcubed on 2006-09-12 14:53 ]
The older I get the more I learn how little I really know.
http://www.sloganizer.net/en/image,s...hite,black.png
speedcubed is offline   Reply With Quote
Old 09-12-2006   #7 (permalink)
Can anyone please give a little better explanation of the pliers technique.........never had to do such a thing and would like to know how its done without damaging anything. Thx
Just got a used 05, lever is fine but who knows what will happen.
JVS1670 is offline   Reply With Quote
Old 09-13-2006   #8 (permalink)
Limited Access
The "Pliers Method" is simply using pliers or similar and grabbing the top of the pad and the outside of the caliper and squeezing the piston back. Do one pad at a time and pull the lever a few times 'til it firms up then do anther pad, this will limit the amount of fluid being pushed back to the MC. Takes a couple of minutes at best.
Old 09-13-2006   #9 (permalink)
hey Limey, could you explain this method in more detail please. like which end do you bleed from when doing this...the bleed nipples or the M/C etc....
thanks
I am STILL thinking to spend on a good vacuum bleeder... do you get better results with those? cant make up my mind.
'****E happens' all the time, so don't go looking for it.
batistuta is offline   Reply With Quote
Old 09-13-2006   #10 (permalink)
Limited Access
This method is not bleeding at all, this is just unsticking the pistons, all nipples are closed. When this method fails to produce a solid feel on the lever its time to bleed the brakes. I bleed by pumping the lever a few times and holding it tight while opening the bleed valve on the caliper (one side at a time) as many time as needed to get as much air out as possible. I'm fed up of doing this, the dealer is going to put new seals in next week, if the problem returns then I will just put the Gsxr brakes on
help..can't get the air out of front brakes! funhunter63 Hinckley Classic Triples 7 04-23-2007 02:20 PM
Front brakes chewey Speed Triple Forum 2 02-20-2007 06:17 AM
Shaking front end when applying front brakes. stealthy1 Daytona Deliberations 10 11-23-2006 04:34 PM
Front Brakes, again! b50bsa Sprint Forum 31 06-11-2006 03:08 AM
Front Brakes pbbeck The Rocket Science Forum 4 10-22-2005 08:49 AM
