BikeBanditMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSpringfield ArmorySportbikeTrackGearTrident-Exhausts.comMotorcycle.comShopTriumph.com
Old 09-11-2006   #1 (permalink)
tsc17's Avatar
Since I can't leave well enough alone, I decided to try upgrading the last untouched components in my brake system...the calipers.
Personally, I never experienced the problems with the OEM calipers that many have (excessive lever travel / mushy feel). I simply figured that if it's a chance for an upgrade, I'm going to run with it! My biggest complaints on the stock ones were lack of initial bite to the brakes, and the fact that there was a bit of drag as well (pistons not fully releasing). I had already upgraded brake pads, brake lines, rotors, and a Magura 195 master cylinder.
I purchased almost a brand new set of 06 GSXR1000 calipers off of Ebay for a whopping $80 for the set. If you buy them brand new from Suzuki, they go for about $280/each!
Since the brakeline mounting location on the GSXR calipers is different from the stock Triumph's, I had to purchase a couple of new fittings, but no big deal. I already had a 28" line on the left, and a 26" on the right. They fit, but the right side was a little tight for my taste, so I ordered up another 28". Now the slack on both sides is almost identical.
One thing that I noticed was that the GSXR caliper pistons release properly (unlike the stock ones). When I took it for a ride, I could tell that I have more initial bite...just what I was looking for. Once you start putting more pressure on the lever, you really start to notice the extra power that you have. I went to hit a small stoppie, and it turned into a really big one in a hurry! I'm sure that once I get some time on these, and get the new SBS Race Sintered pads bedded in, I will like it even more. I'm heading to Mid Ohio here in a few weeks for the real test at track speeds.
On another note, I took apart the OEM calipers and removed the pistons. From what I can tell, these are a coated piston (there's been a lot of debate on whether or not these are). I don't know if they've made any kind of running change (as Triumph is notorious of doing), but it ended the debate for me at least.
So if you're wanting to do this mod, here's what you'll need:
1) 05-06 GSXR Calipers...Ebay for $75 - $100/set
2) 28" Goodridge lines
4) 35 degree banjo fittings
2) 10x1.25mm single banjo bolts (caliper)
1) 10x1.25mm double banjo bolt for master cylinder. Use 10x1.0 with a Magura setup
7) crush washers
1) 19 or 20mm radial master cylinder (aftermarket, or buy the OEM GSXR one...Ebay)
4) GSXR caliper bolts (or modify calipers and use stock Triumph bolts)
4) spacers. I got some nice M10 chrome ones at my local dealer.
ummm, I think that was it...
Since I had the chrome spacers/washers, I also polished the GSXR caliper bolts to match.
Let me know if you have any questions...have fun!
Here's a pic of the OEM Triumph caliper pistons:
2006 Speed Triple. Black. Too many mods to list!
tsc17 is offline   Reply With Quote
Old 09-11-2006   #2 (permalink)
Limited Access
Thanks, mate. Saved that to file
Limey is offline   Reply With Quote
Old 09-11-2006   #3 (permalink)
Yep, that is one thing I need to try. Thanks TSC17!
Reinstated
Devious2XS is offline   Reply With Quote
Old 09-11-2006   #4 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
And they have the added bonus of making it MORE BLACK :-D
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 09-11-2006   #5 (permalink)
tsc17's Avatar
It's almost a spot-on match to the carrier color of the BRAKING rotors!
Old 09-11-2006   #6 (permalink)
TSC17,
Thanks for the write up! Can I ask what the washers were originally for?
So are the stock GSXR bolts to long to use with out washers? or is there not enough thread on them?
Those GSXR bolts look a heck of alot nicer than the stock 06 Triumph bolts on my bike. I'll have to order a set of GXSR bolts.
Thanks!
-Jay
jayb is offline   Reply With Quote
Old 09-11-2006   #7 (permalink)
tsc17's Avatar
The stock bolts are 65mm, and the GSXR bolts are I believe 70mm. I'm not sure if they bottom out or just not enough thread...I had several guys on here say that you needed a spacer, so that's what I did.
As for the spacers/washers, the shop simply had a display of chrome spacers of all sizes. I don't know what the brand was though...
The GSXR bolts are stainless, but I also polished them so that they would look better with the chrome spacers.
Old 09-11-2006   #8 (permalink)
wow, must be nice having brakes that feel right.
going in again on the 15th...
-b
zooplancton is offline   Reply With Quote
Old 09-11-2006   #9 (permalink)
I used 15 deg banjo's on mine. Let's the line come up a bit more in line with the angle of the caliper... I also uses a bit longer lines as my Renthal bars are a tad higher... Great upgrade for the price...
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 09-12-2006   #10 (permalink)
Just got my S3 last week-end (waiting on my title). Any reason the stock MC would not work with the tokico calipers and new lines? Different ratio?
Gerard
05 Black S3 M4 stubby, fat black bars, CRG's, GSXR1000 calipers
06 R6 50th anniversary
96 Ducati 900SS All tricked out
96 Ninja 500 racer
snellen is offline   Reply With Quote
Another GSXR Swap RJScotti Daytona Deliberations 1 12-09-2007 10:18 AM
Any info on an alternator upgrade? ridesouth Twins Technical Talk 8 11-10-2007 08:21 AM
GSXR front calipers for 99 S3 Tarvis Speed Triple Forum 3 07-29-2007 03:27 PM
rocket cleaning info/clarification of mis-info soberdude The Rocket Science Forum 14 10-27-2006 12:30 PM
HELP!!! REAR BRAKE CALIPER FOR '94 900- INFO!!! johnnycactus Daytona Deliberations 2 10-14-2005 12:54 AM
