Motorcycle.comBikeBanditRacerPartsWholesaleMotorcycle.com Classifieds!SportbikeTrackGearTrident-Exhausts.comShopTriumph.comSpringfield ArmoryAdvanstarMotorcycleShows
ShopTriumph.com
Old 09-09-2006   #1 (permalink)
Hi, anybody use this feature yet with a tuneboy.
I know from balancing carbs on my aircooled VW, that you should balance them when under a load, as thats where you would feel any imbalance. It seems like no matter where I turn the adjustment screw, at idle they all read pretty close to the same. I'm still having a stubling issue with my bike. I actually know surges at 4000 rpm. sounds like a missfire. Plugs have been replaced, I checked the ohms of the coils, and they checked out fine.
Dealership said they put a new map on my bike. I have no idea what map though. It got rid of my slight misfire off closed throttle, but now it runs even worse. surging no matter what at like 4000 rpm.
I think they may have but a stock map on my bike. ( I have wolf slipons)
Anyway I'm open to any suggestions to fix this my self.
I thought I would start with making sure the throttle bodies are perfectly in synch.
Thanks
-Jay
jayb is offline   Reply With Quote
Balancing injectors/ throttle bodies on a 01 Triumph Sprint ST Tequila1 Modifications & Workshop Talk 11 03-29-2008 06:14 PM
Can tuneboy be used for throttle body balancing? auraaura Speed Triple Forum 10 02-11-2007 03:20 PM
Throttle Body balancing rktmn3 The Rocket Science Forum 2 05-23-2006 06:52 PM
Throttle Body Sync. cyclesailor Speed Triple Forum 1 03-01-2006 09:56 PM
04 RS Throttle Body Sync drstrange Sprint Forum 2 07-28-2005 06:05 PM
