Springfield ArmoryMotorcycle.com Classifieds!Motorcycle.comRacerPartsWholesaleTrident-Exhausts.comAdvanstarMotorcycleShowsShopTriumph.comSportbikeTrackGear
ShopTriumph.com
Old 09-09-2006   #1 (permalink)
The low fuel light has been coming on lately on my bike when the tank is still over half full. It will stay on for a couple of miles, then shut off. Is there any known issue with these?
Just livin' the dream.
Tee-Dub is offline   Reply With Quote
Old 09-09-2006   #2 (permalink)
Same here. Must be crappy sensor. I haven't noticed it for a while though.
premier is offline   Reply With Quote
Old 09-09-2006   #3 (permalink)
I've had the same issue before. Shut the bike down and fire it back up and all is back to normal.
I never trust that dohicky anyway. 100-110 miles and it's time for fuel.
Probably right, it's a twot of a sensor.
crashmasterd is offline   Reply With Quote
Old 09-13-2006   #4 (permalink)
mine did this just the other day. had 90 miles on the tank when i usually get 120. the light was on for a minute or two and then went off. went another 30 miles before it came back on for real.
tekmoe is offline   Reply With Quote
Old 09-13-2006   #5 (permalink)
I haven't investigated the layout of the tank, but might it be that the sensor is in one side (the same side as the fuel pickup)?
If so, if you're riding in a straight line for a while, the level in that side might get low and trigger the fuel light. Then you go around a corner, brake, or accelerate and some fuel sloshes over from the other side and turns the fuel light off.
As I said, I don't know whether that's possible on our S3s, but I've had exactly this "problem" on past bikes and the above story explained it.
Curmudgeon is offline   Reply With Quote
Old 09-13-2006   #6 (permalink)
For 1050 bikes, use contact cleaner on the fuel pump/level plug contacts - do not use grease or silicone.
Then remove the tank filler neck and reach inside and bend the float arm downward just a bit. It is just a stiff wire with a float on the end. If your hands are big, you will need to remove the pump/level assembly from the bottom of the tank.
This will lower the fuel level when the light is turned on. One gallon is a bit much reserve for a 4.5 gallon tank. Who needs 28.5 % of their tank's capacity as reserve?
I hope this helps.
Reinstated
Devious2XS is offline   Reply With Quote
Old 09-13-2006   #7 (permalink)
If there is any kind of vacuum in the tank , IE: the tip-over valve isn't in the correct position, it will make the low fuel light come on early.
I had to zip-tie mine so it would stay vertical. No more fuel light probs after that.
http://www.rideicon.com/bikes.jsp?bike=6 Perhaps it's reckless behavior - we prefer to think of it as youthful exuberance and character building.
beatpusher is offline   Reply With Quote
Gas Gauge? SamboGARN Twins Technical Talk 29 08-26-2006 03:58 PM
Gas Gauge on '02 ST Panthers_Den Sprint Forum 7 01-10-2006 05:45 AM
Gas Gauge narrowminded Trophy 10 11-10-2005 10:01 PM
Gas Gauge on '02 ST Panthers_Den Sprint Forum 16 09-20-2005 01:39 AM
Gas gauge?? MontrealMike Triumph SuperSports 7 05-23-2005 04:27 PM
