On 2006-09-09 07:53, dr_gallup wrote:
How about some part numbers or links to that relay and the connectors?
Sure. The connector setup are Molex parts. I ordered them through
Mouser. If, like I did, you just want to duplicate the stock setup to plug into the S3 connectors, you will need only one plug/connector setup. The metal connector and plastic casing ("recepticle")are sold separately, and for these recepticles you can order either of two different connectors, depending on the wire guage you are working with. The recepticle is the same for both. (The links that follow go directly to the Mouser page for the part.) The
recepticle is Molex part no. 03-09-1011. The
24-30 guage connector is Molex part no. 02-09-1144. The
18-22 guage connector is Molex part no. 02-09-1119. You will also need to crimp the wire to the connector. I decided to buy a
kit that includes a variety of plastic parts and also a crimping/multi tool. I don't recommend the kit, unless you want to do a lot of work with these kind on connectors (I anticipate that). The crimping tool isn't very easy to use well, but it worked. Other crimping tools or even pliers, etc., may work, but I haven't tried them.
I got the
Flasher relay from
Custom Dynamics for $19.95 plus shipping. I cut the connectors off and put matching conncetors on. I plugged the black relay wire into the middle plug (green/brown wire) and the red relay wire into the plug with the two double orange wires (it's the plug closest to the front of the bike). The flasher works great, and FWIW, it's silent. I need to secure it and the connections a little better, but it shouldn't be a problem. I'll put pictures up if anyone is interested.
[ This message was edited by: Goffe on 2006-09-09 11:42 ]
