No problem Barrie :upthumb:
FWIW I currently have BT020s on my S3 - they're OK but if memory serves me correctly, the OE BT56s that were on the bike when I got it new, seemed a bit better in the wet.
So the dealer MAY be right in some respects, maybe the BT56 was/is better than the BT020 in certain conditions, but to fit an now old-stock BT56, probably because he doesn't have a front 020 in stock, just isn't good enough.
Especially after you as the customer, specified exactly what tyre combination you wanted.
It is possible to mix tyres but you have to be careful about what combination you fit together - you can't just use any old thing that you happen to have lying around like what seems to have happened here.
