Let me just update you on this !!
Turns out it was a simple wiring issue... I will say that the connector block they supply is not the best.. it's suitable for the smaller guage of wire in NOT the larger guage used by Triumph.. I.E it works well with the mad doctor wires but not the triumph ones so basically you get a nice secure connection from the mad doctor stuff but the Triumph ones don't connect in as well... ah well.. just going to have to get a decent replacement connector..
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
