Springfield ArmoryShopTriumph.comAdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comRacerPartsWholesaleSportbikeTrackGearMotorcycle.com Classifieds!
RacerPartsWholesale
Old 09-03-2006   #1 (permalink)
Is it just me or are the high beams useless? My low beams are great and I would not want to point them any lower but when I click on the high beams they are way too high.
soberer is offline   Reply With Quote
Old 09-03-2006   #2 (permalink)
Adjust your lights; mine own.
odium is offline   Reply With Quote
Old 09-03-2006   #3 (permalink)
Small world.....I just came in the house after adjusting mine. We have plenty of trophy size white tailed deer in these parts and it's coming on that time of year when they start moving a lot at night.
Although the low beams have great intensity, I thought they were set too low. High beams seemed OK, but not as good as others considering there are 2 of them.
Vertical adjustment improved the low beams very slightly, but ruined the high beam. So back to square one I guess.
Motorsickle spoken here.
milqster is offline   Reply With Quote
Old 09-04-2006   #4 (permalink)
Favorite Bike: '71 Honda 70
Goffe's Avatar
Get different lights. Hella, Cibie, and Adjure are all significant improvements. No need to go HID in my opinion.
Naked, naked, naked!
Unflappably Nonchalant, with some exceptions
Goffe is offline   Reply With Quote
Old 09-04-2006   #5 (permalink)
Have'nt had probs with mine, very happy so far.
And you KNOW this.........MAAANNN.
itchin is offline   Reply With Quote
Old 09-04-2006   #6 (permalink)
Newbie
Hey I was reading your post regarding the headlights on the Speed Triple and I completely agree. I tried the Adjure Ice headlamps and while they were somewhat of an improvement they still suffer from the stock problem of if the low beams are set right the high beams are too high, I finally tried Hella headlamps P/N: 71456, these headlamps were a significant improvement over stock and give a really good beam pattern on either high or low beam. They run about $60.00 U.S. each but in my opinion are worth it.
dwkelly3 is offline   Reply With Quote
Old 09-05-2006   #7 (permalink)
Rhanks for the tip. Hella 71456 for $46 here.
02S3 is offline   Reply With Quote
Old 09-05-2006   #8 (permalink)
Wow, I was thinking that the headlights, both low and high beam are some of the best I've had since my '96 VW Jetta.
My current vehicle and my Daytona have the newer projector style headlights and although they lay down a specific lighting pattern they arent nearly as bright as the older conventional style of lights I was used to in my older cars, the S3 has been great for me, especially the high-beams, very bright and can see for yards.
rudebwoy85 is offline   Reply With Quote
Old 09-05-2006   #9 (permalink)
Goffe's Avatar
... I finally tried Hella headlamps P/N: 71456, these headlamps were a significant improvement over stock and give a really good beam pattern on either high or low beam. They run about $60.00 U.S. each but in my opinion are worth it.
Exactly what I have. Took me a while to find them though.
Old 09-05-2006   #10 (permalink)
So does one need to purchase the entire kit or can you get similar performance by just buying the replacement bulb? I have tweaked my headlight adjustment and found a happy medium that I think will work out well, but when it comes time for replacement I'd definately be interested in the Hellas.
High beams during the day? pabonne Twins Talk 45 09-11-2007 09:41 PM
High Beams.... stevent Biker Hang-Out 22 02-17-2007 07:17 PM
High Beams Silverado57 Twins Talk 5 04-30-2006 11:41 AM
Riding Eastwards in a Setting Sun and High Beams BlackBeauty Sprint Forum 2 02-08-2006 08:06 AM
Main beams (2) on - Dipped beams (2) off mattbin Sprint Forum 6 10-08-2005 02:56 PM
