AdvanstarMotorcycleShowsSportbikeTrackGearBikeBanditTrident-Exhausts.comShopTriumph.comSpringfield ArmoryMotorcycle.com Classifieds!RacerPartsWholesale
BikeBandit
Old 07-08-2004   #1 (permalink)
Does anyone know if a pipe from a 99-00 s3 will fit (or be able to be modified to) my '02 s3? Also, i bought a daytona pipe "by accident" - price was right so i grabbed it. Does anyone have any idea if that can be modified to fit? the mouth is too wide for my s3. Does anyone make anything that can get it together?
tradedinmyharly is offline   Reply With Quote
Old 07-08-2004   #2 (permalink)
The mid-pipe for a pre-02 is a different shape, or takes a different path, than for the post- '02 models. In '02, the mid-pipe design was meant to account for the presence of a double-sided swing-arm (even though the S3 kept the SSSA), so it has a lot of clearance from the swing-arm than for the older models. You might have to look at it to see what I mean, but it has a ton of clearance. If you call most companies, they'll probably send you the mid-pipe if you already have the stinger in hand. Hope this helps and good luck.
mbeebe900 is offline   Reply With Quote
Old 07-12-2004   #3 (permalink)
If I may ask, what is the p/n (marked on side of can) of that Daytona pipe, which as I understand it, you have for "2002" Daytona 955i, instead of an S3 of the same model year?
Old 07-22-2004   #4 (permalink)
thanks for help and insight... decided not to attemt it.
Exhaust Pipe HtownCruiser Twins Technical Talk 14 02-25-2008 11:41 PM
Exhaust pipe blueing lightguywcl Twins Technical Talk 16 09-01-2007 01:42 AM
exhaust pipe bolt johntog Twins Technical Talk 8 07-07-2007 08:44 PM
Three Pipe Exhaust??? fivehundo Daytona Deliberations 17 05-24-2006 06:24 AM
exhaust pipe cracked tri99sprint Sprint Forum 0 11-08-2004 01:26 PM
