BikeBanditMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSpringfield ArmorySportbikeTrackGearTrident-Exhausts.comMotorcycle.comShopTriumph.com
Old 08-29-2006   #1 (permalink)
found this in a catalog , anybody have an opinion?
http://www.techlinecoatings.com/Retail.htm
HURT SMURT !!!
ctrhenry is offline   Reply With Quote
Old 08-29-2006   #2 (permalink)
Nice find. And it looks like the $20 container would fit the bill.
So who wants to be the first and report back the findings????
Capt.
Captain_Rat is offline   Reply With Quote
Old 08-29-2006   #3 (permalink)
cool, there are a few out there...one comes to mind that a few guys have used on their turbo exhaust housing/manifolds (now that i heat protection!!!) the name slips my mind but from what i've seen results come out pretty nice...as with anything its all in the PREP!
Mesoam is offline   Reply With Quote
Old 08-29-2006   #4 (permalink)
From what I understand, You shouldn't cook food in the same oven.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 08-30-2006   #5 (permalink)
It doesn't look like it needs an oven.
Corse is offline   Reply With Quote
Old 08-30-2006   #6 (permalink)
Yes, it specifically states that it is air-dried.
The thing that I am skeptical about is the temperature drop that they provide in their test example. They claim it dropped from about 200 F to 60 F (measured one inch above the header).
Capt..
Old 08-30-2006   #7 (permalink)
those are some heafty claims, even the professionals @ Jet Hot don't try to sell something that rediculous, was there some fine print where it sayd the second test was done in the antartic???
and no you should not powdercoat in the same oven you cook in ovens can be had for pretty cheap at tag sales and what not so little do it yourself powdercoat operations are easy to start with a gutted oven
Old 08-30-2006   #8 (permalink)
After reading the FAQ's,Mesoam was right on the money regarding the prep. I found that it's not completely a DIY job.
" Parts first must be sandblasted at low pressure (40 psi using a suction type blaster) using fine sand (120 grit aluminum oxide is recommended), NOT with glass bead. Then the part should be degreased using acetone, lacquer thinner, M.E.K. or similar non petroleum based solvent that leaves no residue. The coatings should be applied with an airbrush or detail touchup gun.
Use either an airbrush (not one for pinstriping) or a detail touch-up gun (jam gun). Larger spray units or aerosol spray jars are not recommended. Most coatings spray with 35 psi. The water based coatings work better at 50 to 60 psi."
So, unless you have a REALLY well equipped garage, you'll need to rent a sandblaster and fine paint gun. Or bring it to a shop to do the work. Takes a lot of the DIY out of the equation if you've never done sandblasting and fine air gun painiting before and don't want to test your (lack of) skils on you S3.
Capt.
[ This message was edited by: Captain_Rat on 2006-08-30 06:23 ]
Old 08-30-2006   #9 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Just take it over to Tracker's - he's got the Immaculate Maintenance Facility of Doom. He might even give ya a discount for bein' a forum member.
I'm always wary of cheap solutions - unless I find 'em myself
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 08-30-2006   #10 (permalink)
Just found out through the link there is a place 4 miles from my house that does the coating...I may ride over and see how much it is.
http://www.grahamcrosby.com
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
GrahamC is offline   Reply With Quote
Ceramic Coating Durability Goffe Gear & Gadgets 1 04-02-2007 05:54 PM
Ceramic coating TJRCARRILLO Club Cafe 7 07-23-2006 08:34 AM
ANOTHER CERAMIC COATING QUESTION itchin Speed Triple Forum 8 07-21-2006 12:31 AM
Ceramic coating vs. Powder Coating m_t_yeo Club Cafe 13 04-04-2006 12:25 AM
First Rides and Ceramic Coating TripleTrouble Speed Triple Forum 6 07-28-2004 12:22 AM
