Meanwhile, back at the ranch, this is the stock system with hoses
Here the stock system has been removed now showing the reed valves under neath.
Here the reed valves have been removed.
I cut gaskets and used medium thread locker on the plate bolts. Five of the six bolts are M6x 1.00 @ 20 mm while cylinder one rear has a n M6x 100 @25mm to attach the hose postion clip.
This gasket material is EGR safe.
