On 2006-08-28 02:54, MonkeyHanger wrote:
Yeah mine were well rusted up too. My dealer made a point of showing me when I was in last week. He nor I really thought it to be a problem as they looked healthy.
Same here. I think rusting plugs are a feature of the 955 & 1050 engines, not an assembly fault really. Design fault, most probably yes. The corrosion is always on the outside of the plug and the part that matters, the electrode looks healthy; so I have not bothered to fight the inevitable.
Water collects/moisture condensates in the plug wells and for some reason it does not escape no matter how hot & long you run the engine.
Some have attempted to seal the wells with extra rubber seals, some have attempted to cut a bigger route on the existing seals for the moisture to escape through. The result is the same -> extreme corrosion on the outside part of the plug(s), usually at least on the leftmost one.
Has anyone, anywhere heard of anyone who at the periodic maintenance found all plugs to be in good shape & not corroded at all?
[ This message was edited by: Martin_R on 2006-08-28 04:53 ]
