> I'm having a re-occurring problem with my fuel injection system.
It's not entirely clear that you are.
One thing that is clear: it's not a faulty map. The only reason the off-road map appeared to do anything is because it allowed for a richer mixture that temporarily whitewashed the REAL problem. The real problem--whatever it is--is continuing to get worse.
Your dealer needs to reload the correct map for your pipes, then start some serious diagnostic work. He should be looking for bad sensors, air leaks, throttle body imbalance...all the usual suspects.
John
