Springfield ArmoryMotorcycle.com Classifieds!Motorcycle.comRacerPartsWholesaleTrident-Exhausts.comAdvanstarMotorcycleShowsShopTriumph.comSportbikeTrackGear
ShopTriumph.com
Old 08-20-2006   #1 (permalink)
jimmydean's Avatar
Last two rides I noticed my front brake squeek when stopping at a light. Then this morning i backed out of the garage and they were squeeking. Anyone else?
2600 miles ............What gives
A few weeks ago I was playing around and did a few stoppies but that's it.....havent done it since.....i swear!
jimmydean is offline   Reply With Quote
Old 08-21-2006   #2 (permalink)
Not had any problems on my s3 but my Tiger was a nightmare!
Had pads and discs changed but it made no difference they still squeaked. It got so bad i changed my braking technique, letting the brake off just before stopping then pulling it back on!
As usual Triumph denied any knowledge of the problem.
worthy1 is offline   Reply With Quote
Old 08-21-2006   #3 (permalink)
you ruined them jd!!! :-D
cheapbastard is offline   Reply With Quote
Old 08-21-2006   #4 (permalink)
mine did the same thing before my caliper swap. Just one of the many reasons to ditch the Nissins.
gr8shandini is offline   Reply With Quote
Old 08-21-2006   #5 (permalink)
jimmydean's Avatar
Hey cheap- swap me yours!
I don't have the cash for new calipers. Will this fade?
Old 08-21-2006   #6 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
This has worked for me on all my bikes and cars.
Remove pads. Take a file (or an angle grinder if you're brave) and file a 45 degree champfer off the edges of the pad material. Clean up the insides of the calipers while the pads are out and put them back in.
This method can also stop the clicking some of us get.
If you're rotors are all shiny and glazed, this will also cause a squeal, so take a piece of fine emery and scuff the rotor up a little, taking care not to make it too rough.
Mick
[ This message was edited by: miker on 2006-08-21 20:29 ]
My Album
miker is offline   Reply With Quote
Old 08-22-2006   #7 (permalink)
A VERY THIN smear of high melting point or copper grease on the BACK part of the pads + what Miker said.
WHen you fit new pads, treat 'em gently till they get run in, otherwise squeeling most probably gets included free with the deal.
Avi8or is offline   Reply With Quote
Old 08-22-2006   #8 (permalink)
Avi8or can you be really specific about where on the back to put the copper grease. i just dont want to get that wrong with brakes.
cheers
officer you try and keep it on two wheels
Celt is offline   Reply With Quote
Old 08-22-2006   #9 (permalink)
On the metal part of the pad that contacts the caliper pistons. Grease will melt with heat and you DO NOT want any on the pads or disk, so just a little smear. It will act as a damper and hopefully prevent vibes and squeals.
it breaks my heart but... PIP1980 Sprint Forum 6 10-10-2006 08:54 PM
Rear Breaks 76 Bonnie Klicker Classic, Vintage & Veteran 8 06-09-2005 07:13 PM
Breaks Klicker Classic, Vintage & Veteran 16 02-03-2005 07:50 PM
Best breaks? rskeenan Trophy 11 09-03-2004 08:24 AM
squeaky breaks on 02 tiger Tiger Chat 1 06-16-2004 03:42 AM
