08-19-2006, 09:52 AM
I just bought a Fiamm HK9 RoadThunder from RideSafer.com
RideSafer.com
The site says
"* Low current draw (4 amps) allows the horn kit to be installed in most stock horn circuits. A new horn circuit is NOT required in most cases."
I want to make sure I don't cook the horn switch because I'm sure it's not cheap to replace. Last time I upgraded a horn (on my CB750) I did the whole wire-through-the-relay thing. When I did the search, it looked like most people were wiring through a relay and I had planned on doing that but then I saw the blurb about how this horn can be installed on most stock horn circuits.
Anyone know what the current draw of the stock horn is?
08-19-2006, 11:16 AM
Pretty simple realy. If the stock horn fuse is 4amp, then just wire it up. Amps are amps.
Just livin' the dream.
08-19-2006, 11:57 AM
plenipotentiary
Site Supporter Supernova Favourite Bike: Speed Triple
Posts: 22,412 Other Motorcycle: CBR1100XX Extra Motorcycle: Piaggio MP3
Agree with Tee-Dub,
I just wired mine in place without any problems.
I like to reminisce with people I don't know.
08-19-2006, 12:39 PM
Pole Position Favourite Bike: 2003 Triumph Speed Triple
Posts: 3,343 Other Motorcycle: 2007 Ducati 1098
I just got a 115db PIAA horn I'm going to try out.
08-19-2006, 12:55 PM
Actually, I thought of that, Tee-Dub. Problem is, the horn shares a fuse with the headlights (high and Low) on my bike. It's a 20.
Any way to know what the stock horn switch is rated for? I have a multimeter, maybe I'll just turn on the bike, hook the multimeter up and hit the horn to see what the draw is. Problem is, I'm not too sure how to hook up the multimeter to get the desired readings. I've only ever used it to check for continuity and to check the charging system.
Anyone know how I could do this?
08-19-2006, 02:50 PM
No problem - but if your meter doesn't read AT LEAST 5A DC, find another meter before you measure.
Pull one of the wires off the stock horn. Hook one multimeter leads to the horn terminal that you've just exposed, and the other to the wire you've just pulled. Set the meter to read DC AMPS - on many meters, there is a separate place for the plus (red) wire to plug into the meter for "high" amp measurements. Hit the horn button. If the multimeter is analog, you've got a 50-50 chance of the polarity being correct - if it tries to read below zero, reverse the two leads. Nothing to be damaged. Digital meters usually don't care - they'll read either way as either + or -.
And there's no reasonable way to measure the capacity of the switch, AFAIK. But please let us know what you find...
Good luck,
vinny
Be nice to America or we'll bring democracy to YOUR country...
08-19-2006, 06:20 PM
Got my PIAA horn installed in the stock position. Looks decent enough and is LOUD compared to stock. Should be amusing harassing my buddies on sunday rides, hehehe.
08-20-2006, 03:13 PM
Try pm to 1050pomme,i noticed he had a different horn on his but don't know what it is. :hammer:
Bucket
08-20-2006, 03:34 PM
I have air horns on my bikes -they are really LOUD. STEBEL Nautilus makes two types one smaller than the other . Got em from Girots Garage. They really sound out and do require a relay. I like them!!!
2007 Tiger "Old Blue"
2004 Thruxton "Big Red"
2006 Sprint ST ABS "The Blue COW"
08-20-2006, 10:45 PM
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
The Search Feature...
omaz |
Sprint Forum |
0 |
07-16-2007 07:40 PM |
upgrade horn for Bonnie
jerseyjeff |
Twins Technical Talk |
15 |
04-14-2007 10:32 AM |
Horn UPGRADE
tigertales |
Tiger Mods & Bolt-Ons (archive) |
1 |
07-25-2006 05:31 PM |
Girder Search
Classic, Vintage & Veteran |
0 |
12-19-2004 10:55 PM |
Search ??
Quackster |
Speed Triple Forum |
3 |
08-08-2004 11:04 PM |
