BikeBanditMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSpringfield ArmorySportbikeTrackGearTrident-Exhausts.comMotorcycle.comShopTriumph.com
Old 08-17-2006   #11 (permalink)
On 2006-08-17 09:07, Curmudgeon wrote:
I don't know this from personal experience, but others have posted on this board that there are connectors within each front turn signal stock. You should be able to disconnect those and remove the turn signals with no ther disassembly.
That is EXACTLY what I did when I painted the radiator shrouds. I can tell you this much..... they look good for a while, but then the stone chips start and they start looking tack fast. I have had to pull mine back off once for a repaint already. They seem to last for about 2 to 3 months depending on how much you ride.
TonUp wrote:
Are you a Hooligan? I know that Corners and Cheapbastard are for sure and so am I!!!
http://i56.photobucket.com/albums/g1...-hooligans.jpg
corners is offline   Reply With Quote
Old 08-17-2006   #12 (permalink)
The amount of time you spend on here debating whether or not to do it, is enough time to make the money to buy CF gaurds :hammer: :hammer: :hammer:
Just jealous mostly, I don't have the time to do anything to my scoot right now.......
beefjenius is offline   Reply With Quote
Old 08-17-2006   #13 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Hmm... but her body gets the sheep's head. Makes a funny noise when ya pinch her. Don't ask how I knows this.
As for the 'spearmint itself, I am reminded of the old saw: "The operation was a success, but the patient died.
Lessons learnt?
The metalcast works as advertised, but it is VERY finicky. Of the four parts, only one came out right on my first shot. One of the radiator shrouds looked very nice, a dead ringer for anodized aluminum. Of the others, I put too heavy a coat on two of 'em and they were just blue, while the third showed its imperfections.
Basically, it's a tinted clearcoat, so you have to be very careful to keep the spray the same distance all the way across the part or you get dark spots. As with everything, several light coats works best. Being a tint, it seemed to magnify slight differences in color so even if you are careful, you still end up with a weird cast to it.
If I was doing it over again, I'd use a base coat of silver to get it even. Of course, that would have meant stripping it all down and starting over again, which would have been worth it except...
The anodized blue color just does not go well. I like it on the rim stripes, I like the blue suspension adjustment gizmos on the forks, and even the blue on the rear shock spring, but even the radiator shroud that turned out nice looked outta place, so...
They all git stripped and it's back to black. Seven bucks, a couple o' hours, not a bad way to spend an afternoon.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 08-17-2006   #14 (permalink)
BLACK---oh boy is this a color thread :razz: :razz: :razz:
TrackerOldGuy is offline   Reply With Quote
Old 08-17-2006   #15 (permalink)
R100Pilot's Avatar
Yeah. The blue probably woulda slowt it down some. And god forbid I put the yeller onnit!
— HST
Old 08-17-2006   #16 (permalink)
On 2006-08-17 08:28, R100Pilot wrote:
What would Tim Allen do?
blow some lines and get to work...
05 Speed Triple
jdub3 is offline   Reply With Quote
D-Tool option? JAXTRIUMPHGUY Twins Talk 12 01-07-2008 05:36 PM
A new flyscreen option FL_Rat_Matt Speed Triple Forum 17 11-09-2007 05:47 PM
Shock option vertwrks Club Cafe 8 07-09-2007 01:16 PM
New Option from Triumph oldmanjob Twins Talk 3 06-16-2007 01:27 AM
Windscreen option RickyT Sprint Forum 4 12-21-2005 06:37 PM
