BikeBanditMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSpringfield ArmorySportbikeTrackGearTrident-Exhausts.comMotorcycle.comShopTriumph.com
Old 07-02-2004   #1 (permalink)
Well...after totalling my 01 Sprint ST in February, I am finally back on a bike. A nice brand new RED Speed 3! I got a new pair of Alpine Star SMX3 boots and I am having trouble getting the shift lever adjusted correctly. The two positions it works OK on...the lower one is too low... and one tooth up and it's too high. Is there some sort of other adjustable lever or maybe just the toe piece with an eccentric adjustment?? Ideally...exactly in between the current two positions would be perfect. Any ideas??? Thanks!
John
John
"What if the hokey pokey IS what it's all about?"
iscarian is offline   Reply With Quote
Old 07-02-2004   #2 (permalink)
I had a similar problem with my 03 Speed 3 since I bought a set of Alpinestar Touring boots and I had to adjust the lever a few clicks up. Another option you may try is a set of Lockhart Phillips Adjustable pegs. They manufacture a set you can rotate up or down but you will have to modify a set for a ZX-7 Kawasaki since they have yet to manufacture a set for a Triumph. There was another member who put a set on a Daytona with great results. Hope this helps
Scott
nyspeedtriple is offline   Reply With Quote
Old 07-02-2004   #3 (permalink)
Of course you could always spend $500 and buy the adjustable rear set from SkyKing (ouch!)
Captain_Rat is offline   Reply With Quote
Old 07-02-2004   #4 (permalink)
Maybe *you* will adjust??? Could you maybe try different boots? Anyways, congratulations on buying the world's best bike and in the best color, too. (Am I a little biased or what?). :-D
beers2u is offline   Reply With Quote
Old 07-04-2004   #5 (permalink)
You wouldn't really need fully adjustable rearsets but if you could find an aftermarket set that used a linkage that'd be ideal, provided the linkage offered some adjustment. Might try SpieglerUSA.
tomhorn is offline   Reply With Quote
Old 07-04-2004   #6 (permalink)
Thanks for the ideas. I think Beer may be correct in that I will adjust...BTW...you can be biased all you want...cus your right!!! I have had the bike two weeks now and just rolled over 1000 miles today!!! Did I mention how much I love naked red heads :-D
John
John
Old 07-08-2004   #7 (permalink)
Try www.n-w-s.com they do an adjustable lever. The "toe peg" itself moves, rather than the lever itself. Worked for me.
Does not play well with others!!!
Windchill is offline   Reply With Quote
Gear shift lever adjustment davidc Twins Technical Talk 6 07-07-2007 06:20 AM
Need a shift lever 2bugeyez Speed Triple Forum 0 03-19-2007 10:53 PM
Shift lever laying around? tri650 Classic, Vintage & Veteran 3 08-08-2006 12:27 PM
Shift Lever Fitch Sprint Forum 1 06-06-2006 09:28 AM
shift lever- @!&$$&% Longshot92 Modifications & Workshop Talk 5 11-11-2005 07:37 AM
