Mine was leaking oil from a loose sensor, just behind the end of the starter, it looks kinda like a spark plug with a thin black wire attached to the top.
Check to see if there is oil pooling around it. The oil would pool, and when I set the bike on its kick stand, the oil would drip next to it... It eventually got really bad within a couple days, And I had a 4 inch pool of oil under the bike after every ride.
I took it in to show the dealer, They cut the wire, tightened the sensor, Spliced the wire, Job is done.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
