On 2006-08-12 21:33, 1050Pome wrote:
limey, are they an easy installation ( the indicator light thing) ? It says you get number plate lights as well, how do they fit? Are the indicators bright enough in sunlight? Looks well cool I reckon.
Cheers.
Easy install, just plug and play. very bright, even in the Florida sunshine. BTW, in that picture the plate was mounted too low, in now sits a little higher, I had it mounted to the wrong bolt on the rear foot pegs, front bolt instead of rear so it is a little more visible. The number plate lights are LED bolts that mount the plate, very cool. with that kit you get all the wiring and a new flasher relay, and the rear light. :-D
