Old 08-12-2006   #1 (permalink)
Hi guys, I bought a tuneboy for my bike to try and fix the hard starting issue I have, and to maybe get a few more ponies while I am at it.
Looking at the tuturials on the tuneboy site, on how to zero the tps......I dont have screen that looks like that. (unless its hidden somewhere)
I'm running the ver 3 software downloaded from there site yesterday.
Can anyone share with me, how to do this? Is it in the diag program, or the edit program?
Thanks!
-Jay
jayb is offline   Reply With Quote
Old 08-12-2006   #2 (permalink)
I'm going to mess with mine today, hadn't noticed the TPS reset. I wonder if it's like many other bike where you turn the ignition on and roll the throttle closed to wide open 3 or 4 times before starting.
littlefield is offline   Reply With Quote
Old 08-12-2006   #3 (permalink)
Favorite Bike: '01 Speed Triple
The TP Reset is in the Tuneboy diagnostic. Open up Sensors, and the closed throttle reset is right above the exit button at the bottom right. I had to look for it too. The tutorial shows a different skin.
Speed3 is offline   Reply With Quote
Old 08-13-2006   #4 (permalink)
Acording to the documentation it says closed throttle reset and co adjustment are only supported by the Sagem ecu not the Keihin ecu.
Tim
Tim_Z is offline   Reply With Quote
TPS Gone- What a difference!! CAPTDON Twins Talk 65 01-14-2008 12:59 PM
Tps Sensor Harold The Rocket Science Forum 3 10-15-2007 08:05 PM
TPS and BC ECU SCCTrim Twins Technical Talk 48 04-30-2007 09:27 PM
TPS? mikeinva Twins Technical Talk 7 04-03-2007 09:29 PM
Procom unit and TPS stu Twins Technical Talk 0 11-28-2006 06:02 PM
