On 2006-08-10 10:21, Tritanium wrote:
Any chance you might be able to tell us how they "jacked up the rear"? Did they insert a shim at the shock mounting point? If so, what thickness?
Since the mounting bolts for the rear shock are horizontal, a shim wouldn't work. Since the setup was £40, I assume the shop jacked up the rear by increasing the rear pre-load (and didn't actually increase the effective length of the shock).
Incidentally, I'm a big advocate for doing just that. As delivered, my bike had far too much rear sag (and not enough front sag). I set the rear (rider) sag at 28 mm and the front at 35 and it now handles much better.
