Springfield ArmoryAdvanstarMotorcycleShowsMotorcycle.com Classifieds!SportbikeTrackGearTrident-Exhausts.comMotorcycle.comBikeBanditRacerPartsWholesale
Old 08-09-2006   #1 (permalink)
Hey, how do you tighten the chain on the S3?? Is it just a link removal or is there any other way?? I have a track day coming up and it needs to be done so I pass tech inspection.
Where has all the RUM gone???
JackSparrow is offline   Reply With Quote
Old 08-09-2006   #2 (permalink)
Hey Captain Jack,
Your owners manual gives a good description of how to adjust the chain.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 08-09-2006   #3 (permalink)
easiest chain I've ever adjusted! You just loosen the pinch bolt on the swingarm, and use your spanner wrench from the toolkit to lock on the chain adjuster on the hub. Can't remember, but I think clockwise tightens, but you'll figure that part out! :-D
cheapbastard is offline   Reply With Quote
Old 08-09-2006   #4 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Yeah, I remember I was out riding after I'd just gotten it, an' me an' my Hurricane riding friend were starin' at the thing, scratchin' our heads an' wonderin' how to adjust the tension.
Then I looked at the owner's manual. Ingenious gizmo!
When all else fails, read the instructions :-D
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 08-10-2006   #5 (permalink)
Thanks guys. Never fails that I forget to look in the most obvious place. And all along I just thought owners manuals were for oil capacities and tyre sizes.
Old 08-10-2006   #6 (permalink)
Jack,
a point to remember, with the S3 a correctly adjusted chain appears to have a lot more slack in it that other bikes. Follow the manual's instructions carefully.
When I am finished, I get on the bike, and I reach down and check the slack with my weight on it. Putting the weight on the bike takes up a lot of the slack. After my first service (at a Triumph dealer) I rode away and the bike felt funny. I stopped and checked the chain and with my weight on it it was bowstring tight. Without my weight it seemed OK.
(I've since changed mechanics). So even supposedly trained mechanics can get it wrong.
John
Old 08-11-2006   #7 (permalink)
THanks for the input guys, got her all snugged up and ripping up the streets. Sliders installed, indicators removed and ready for the track.
How can I tighten up the mirror??? funhunter63 Trophy 1 11-12-2007 10:34 AM
The Crank is out, new cam chain on, set your wrenches to tighten! sweatmachine Twins Talk 39 05-03-2007 10:00 PM
CHECK/TIGHTEN YOUR BOLTS!!! mikesitter The Rocket Science Forum 7 10-27-2006 12:52 AM
Tighten your bolts !!! dazco Twins Talk 33 09-25-2006 09:14 PM
HOW DO YA TIGHTEN THE CHAIN?????? JDMoney Twins Talk 9 06-26-2005 07:13 AM
