hmmm...***!
i was coming home from work today and i was in 6th gear doing about 2200rpm. i gave it full throttle to pass a car and the bike started chokin!!! like p-p-p-p-p-ppp-p-pp-vrrrrrrooooom! after it gets to about 2600rpm, it runs like the beast it should.
dammit. i hope theres not something wrong with it. i did adjust the throttle cable about a week ago. can't remember the last time i gave it full throttle in any gear that low of an rpm. i tried it in 4th and 5th and it did the same thing before i got home.
i will adjust the throttle cable back to what i had it at. i only adjusted it because i figured after 4500 miles, it probably had some slack in it.
if you adjust the throttle cable too much, is this symptom common? i hope so. =/
