Trident-Exhausts.comMotorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 08-05-2006   #1 (permalink)
beemer_dog
Fellow Rats
Whilst in the process of removing the fuel tank to replace plugs and air filter I noticed some fuel staining near the connectors that go into the pump/tank.
Trying to remove one of the hoses by pressing the spring loaded tab on the plasitc fitting cause it to fracture and ultimately break off.
Now I have the thread of the plastic connector stuck in the fitting plate. Seems like a ***** idea to use plastic fittings, which stick out so far.
Anyone had this problem, and how to you get the thread out?
Old 08-06-2006   #2 (permalink)
I've had the same problem. There is a metal fitting parts somwhere you can order, that should stop this from happening. THe plastic triumph uses is very weak. There is a recall for the hose side plastic fittings from Triumph.\\
I got the plastic off the tank by heating it up with a soldering gun. Then a flat head screw driver to move it out.
Good luck
http://www.lusori.com
Cement/stone/brick work in DC/MD/VA
http://www.cycleposers.com
forum for motorcycle idiots, retards and morons
roadkill is offline   Reply With Quote
Old 08-06-2006   #3 (permalink)
Favorite Bike: '01 Speed Triple
The recall fittings from Triumph aren't that great. Here is a link to a dealer that has top quality metal ones.
RideTeamTriumph
Speed3 is offline   Reply With Quote
Old 08-06-2006   #4 (permalink)
You're not alone. I had the same thing happen...
http://www.corbell.org/images/avatar.jpg
Shut your eyes and you'll burst into flames
dcorbell is offline   Reply With Quote
Those Fuel Connectors CaMojo Tiger Workshop 3 05-06-2007 06:20 PM
S3 fuel connectors martinyoung Modifications & Workshop Talk 5 11-15-2006 08:23 AM
955i Fuel Connectors Captain_Rat Speed Triple Forum 2 09-24-2006 09:23 PM
S4 fuel connectors - replacement Catenaccio Modifications & Workshop Talk 5 07-04-2006 12:09 PM
Fuel Connectors NODDY Sprint Forum 7 07-12-2005 11:20 AM
