10,000 km service question/Seeping head gasket - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-02-2006, 08:27 PM   #1 (permalink)
Favourite Bike: 2004 S3--black
FelixLeiter's Avatar
So, the 10,000km (6000mi) service entails everything from the 800km (500mi) service---oil/filter, checking codes on the ECU, and tightening/adjusting all the bolts/brakes/chain/clutch PLUS checking the spark plugs, right? I imagine that checking the plugs will be an additional 1/2 hour labour so I'll likely be looking at $300 for the service.
Now, 100mi outside of Nelson BC (on my way to the Raid) I noticed a burning oil smell. The head gasket on the RHS front corner of the engine (right behind the oil cooler) was leaking (seeping) a bit. Over the course of the next 1500km I didn't lose any significant amount of oil but it needs to go in for warrantee work. I'm thinking that the amount of work to get to this gasket (removing the tank, cam cover/plugs and head) should help reduce my 10,000km service bill, right?
Yr Fthfl Srvnt
FelixLeiter is offline   Reply With Quote
Oil seeping out from under the head cover on my Scrambler ddmhnl Twins Technical Talk 7 10-22-2007 02:19 PM
12,000 mile service question RickyT Sprint Forum 13 08-26-2007 11:07 PM
question about changing my head gasket/valve adjustment jwpT100 Twins Talk 12 11-09-2005 03:32 PM
2004 - seeping head gasket? argh Speed Triple Forum 8 10-25-2005 08:53 PM
Head Gasket??? flick427 Twins Talk 8 08-02-2005 12:36 PM
