Fan comes on same as before. Stop/slow will have it running. This is normal for THIS bike. However sick fan=overheating when slow/stopped.
The cooling system of the S3 runs at 1.2 bar which is quite a bit more than your average .9 bar.
What this basically means is that Triumph can get away with a smaller rad running at higher temps, 'cause water, coolant whatever, boils at a higher temp when under pressure.
Whilst at the moment this is not really a problem, and the rad size is able to cope, with frequent fan assist when slow/stopped, my feeling is that as the bike gets older and fur starts building up inside the coolant passages, block, and radiator, also exposed to road filth, the cooling efficiency will deteriorate and overheating may be a serious problem in the future.
Keep your rad grilles clean or the thing may boil over.
Whoever's gonna keep th ebike long term should start lookin' for a larger/thicker rad.
