SportbikeTrackGearMotorcycle.comAdvanstarMotorcycleShowsRacerPartsWholesaleShopTriumph.comTrident-Exhausts.comSpringfield ArmoryMotorcycle.com Classifieds!
Springfield Armory
Old 07-30-2006   #1 (permalink)
Favorite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
So I decide to try gettin' a ride in before the afternoon rains hit, and Speedy has a hard time startin'. Once it's running, I turn the throttle and it stalls out. Start again, ease it on, it revs up but sounds a little rough. Hmmm...
Riding through town to meet the girlfriend for some Chinese for lunch before Heading out, it still seems a bit off, a bit hesitant when I crack the throttle open.
So after lunch I stop to top off the tank, put the key in, and the cap won't open. Turn, press, cuss. This is weird. So I turn the key with one hand and pry up an' the thing sounds like I'm openin' a vacuum packed jar o' peanuts or somethin' -sssssssssssssPOP.
I mean, that thing was stuck tight.
Fill it up and off we go - runs a lot stronger, no hesitation.
Very weird - never had a problem with the venting before. Tank was only down about 1/3. When I got home, I popped the cap just to see if it was doing it again, and it opened right up, no problem.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 07-30-2006   #2 (permalink)
might be a case of the old stuck tip valve in the breather.. check the breather hoses for kinks also...
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 07-30-2006   #3 (permalink)
It's the dreaded "Kinked Tank Breather Syndrome." Somehow you've kinked or pinched your fuel tank breather. This is a known issue with an obvious and easy fix.
Just straighten out the hose or cut it off short.
crashmasterd is offline   Reply With Quote
Old 07-30-2006   #4 (permalink)
R100Pilot's Avatar
Lemme guess - gotta pull the gas tank off to check this?
— HST
Old 07-30-2006   #5 (permalink)
I had the same problem early on, check that in-line little black plastic valve on your left side in one of the drain/vent tubes, about ankle high, make sure it is vertical.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 07-30-2006   #6 (permalink)
Hey R100Pilot,
I had the same problem early on, and after checking the hoses, (you don't have to remove the tank), I found the one way valve on the end of the breather valve had turned into a no way valve. I pulled the cheap and nasty plastic f*cker off and threw it away. No problems since.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 07-30-2006   #7 (permalink)
Yeah, what legman said. It can be easier to fiddle with the hoses if you remove the left hand side plastic, but not really necessary.
The one with the one-way valve is the tank vent, and the straight line is the fuel fill drainage hole. Pretty straightforward.
Old 07-30-2006   #8 (permalink)
R100Pilot's Avatar
Thanks for the tips. Been ridin' around in the rain. Maybe some dirt or mud got up in there. Probably take the thing off - less is more.
— HST
Old 07-31-2006   #9 (permalink)
Same thing here. Mine was stuck closed. I threw it away.
-Jay
jayb is offline   Reply With Quote
Old 07-31-2006   #10 (permalink)
yup also had the same thing happen to me. i removed the charcoal box or whatever that little thing disc shaped thing is and threw it away.
tekmoe is offline   Reply With Quote
D1200 stumbling out of Idle pathunderbird Modifications & Workshop Talk 3 10-01-2007 09:46 PM
Trying to get to grips with the situation.... Doc007 Speed Triple Forum 3 08-22-2007 10:52 AM
sucking it flat HeyMan Tiger Chat 3 12-18-2006 12:43 PM
Pinging? Sucking Air? What the H*LL is this noise? livefree63 Speed Triple Forum 16 08-06-2006 01:14 PM
The Flyscreen Situation Spooner Hinckley Classic Triples 13 04-26-2005 05:27 AM
