The way you'll know the difference between an 01 and earlier cowl and 02-04 is there will be four plastic posts sticking out of the bottom of the 01 which rest on the frame and a single plastic tab toward the front which hooks under the crossmember where the seat bolts on and a metal peg at the rear for the lock. (LOOONG run-on sentence, sorry)
On an 02-04 there will be two metal arms which hook under the crossmember on the sides (rather than the middle like the 01), and just the metal rear peg for the lock.
Oh, also, the 01 has several screws which hold the rear cowl on. These are located where your butt meets the cowl. The 02-04 has all the bolts located on the underside of the cowl.
01 doesn't have a rubber butt-stop, both of the 02-04 style do.
