Springfield ArmoryAdvanstarMotorcycleShowsMotorcycle.com Classifieds!SportbikeTrackGearTrident-Exhausts.comMotorcycle.comBikeBanditRacerPartsWholesale
Old 07-25-2006   #1 (permalink)
tsc17's Avatar
I've checked some other posts, and it looks like the older models are 17mm. The '06 looks like a 21 or 22mm. Can anybody confirm this?
Thanks.
2006 Speed Triple. Black. Too many mods to list!
tsc17 is offline   Reply With Quote
Old 07-25-2006   #2 (permalink)
I believe 22mm is the correct one you're look'n fer!
cheapbastard is offline   Reply With Quote
Old 07-25-2006   #3 (permalink)
yup it's a 22 and/or you can do what I did and get a standard bolt with 2 nuts that are 7/8 od and lock the 2 nuts together at the bottom of the bolt and use that.
TonUp wrote:
Are you a Hooligan? I know that Corners and Cheapbastard are for sure and so am I!!!
http://i56.photobucket.com/albums/g1...-hooligans.jpg
corners is offline   Reply With Quote
Old 07-25-2006   #4 (permalink)
Or find a 3/8" drive spark plug socket with 7/8" flats at the top to use with an open-ended wrench. Insert the top end of the socket into the axle and use a 3/8" extension bar backwards (inside the socket) on a 3/8" ratchet to turn the axle loose. The nice thing is this allows you to put a 3/8" drive torque wrench on it when you're reinstalling the axle.
[ This message was edited by: Curmudgeon on 2006-07-25 11:00 ]
Curmudgeon is offline   Reply With Quote
Old 07-25-2006   #5 (permalink)
On 2006-07-25 10:57, Curmudgeon wrote:
Or find a 3/8" drive spark plug socket with 7/8" flats at the top to use with an open-ended wrench. Use a 3/8" extension bar backwards (inside the socket) on a 3/8" ratchet to turn the axle loose. The nice thing is this allows you to put a 3/8" drive torque wrench on it when you're reinstalling the axle.
Thats a great idea too....
Old 07-25-2006   #6 (permalink)
tsc17's Avatar
I bought the Motion Pro multi-tool. It has a 17, 19, 22 and 24mm built into one slick unit.
front axle size farmhand777 Speed Triple Forum 1 10-19-2006 01:29 AM
size for front forks pinch bolts for axle? tekmoe Speed Triple Forum 1 08-14-2006 11:36 AM
2000 TT 600 front axle tool size? OhiomaleCop Triumph SuperSports 4 06-23-2006 01:40 AM
What size hex key? Avatar Hinckley Classic Triples 9 04-15-2006 09:57 PM
Hex key size of 1050 front calipers? Martin_R Speed Triple Forum 10 03-15-2006 03:16 PM
