RacerPartsWholesaleSpringfield ArmoryBikeBanditTrident-Exhausts.comMotorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!AdvanstarMotorcycleShows
SportbikeTrackGear
Old 07-24-2006   #1 (permalink)
I'm attempting to install my new Arrow exhaust on my 05 and it seems impossible to get the cans to line up properly. Any one with experience want to chime in and give me the secret technique? I have been pulling, bending and pounding on this stupid pile of ***** for the better part of an hour now and the right can is still about 1.5 inches higher than the left!
Just livin' the dream.
Tee-Dub is offline   Reply With Quote
Old 07-24-2006   #2 (permalink)
T,
Make sure the "straps" that hold the cans to the bike are loose, or at least make sure you play with them. if they hold the can too far back or forward they really effect the way they sit. Also, keep the connection from the mid-pipe to the "header" pipe loose. I found that rotating/twisting the mid-pipe at that location made a big difference.
Good Luck!
buzlin is offline   Reply With Quote
Old 07-24-2006   #3 (permalink)
I fiddle farted around with adjustment for about 1.5 hours and got it "close". I'm very finicky so I know it will probably drive me nuts.
It definitely feels stronger, wheelies easier, and sounds better, a true hooligan now! A lot of popping though, so I may need to try and cover up the air thing in the airbox. Plus, it is still on the stock map, my Power Commander should be here any day!
Old 07-24-2006   #4 (permalink)
t,
yeah, with the baffles removed there's pretty wicked popping, sounds cool for a little while, but eventually gets old (as you know). i noticed a bit more low end grunt and seemed to wheelie easier too, but might have been in my head.
glad you were able to get it on somewhat straight. perfection is hard to live with out!
tom
Arrow Exhaust Simmons Twins Technical Talk 16 05-19-2008 10:22 PM
Arrow Exhaust Question bruiser06 Speed Triple Forum 7 11-29-2006 02:52 PM
NEW Arrow exhaust Bluetahoe Speed Triple Forum 21 10-06-2006 08:57 AM
ARROW Exhaust KarmaPunk1 Speed Triple Forum 13 07-07-2006 01:55 PM
Arrow Exhaust waterdawg Speed Triple Forum 39 10-07-2005 10:50 PM
