monSTAR, clutch cable on a 2001 model should be simple. Not sure how much a cable will be over there, here in Aus, they're about $70.
Fitting is easy, so long as you check how the old one comes out, replace the new one the same way. Then adjust it according to the owner's manual.
If you're not up to it, a dealer shouldn't charge you very much to do it.
Mick
