Trident-Exhausts.comSportbikeTrackGearRacerPartsWholesaleMotorcycle.com Classifieds!ShopTriumph.comAdvanstarMotorcycleShowsSpringfield ArmoryMotorcycle.com
Old 07-20-2006   #1 (permalink)
as you all know, i had the TORs map installed last weekend. since then, i have noticed my bike takes longer to start when cold. before it wasn't too bad. now i have to hold the starter down for about 4 to 5 seconds before it fires up. sux.
tekmoe is offline   Reply With Quote
Old 07-20-2006   #2 (permalink)
Limited Access
prob all the booze fumes choking the intake. :-D :hammer: :razz:
Limey is offline   Reply With Quote
Old 07-20-2006   #3 (permalink)
oh schit! we aren't supposed to use everclear in the tank???
:wink:
Old 07-20-2006   #4 (permalink)
Not a back to back comparison, but my first S3 started with only a second or two of cranking, the engine was totally stock. My second S3 with Trident 1/2 pipe and TORS tune takes 3-4 seconds cranking to start. I get a nice wiff of raw gasoline from the pipe so I don't think it is fueling. Usually a rich mix will fire up while too lean will definately cause cold starting problems. I suspect the spark timing is not optimum at cranking. Lots of people report this problem. Would be interesting to see the differences in the maps.
dr_gallup is offline   Reply With Quote
TORs with standard map ok? Lom Speed Triple Forum 10 04-03-2007 02:35 PM
PCIII Map for TORS + K&N fryingtonite Speed Triple Forum 16 03-18-2007 04:19 PM
TORS Map Dobieman Speed Triple Forum 5 12-06-2006 12:40 PM
stock map or tors map after exhaust upgrade? tekmoe Speed Triple Forum 6 07-15-2006 12:21 PM
TBS TORs no longer available Wombat Hinckley Classic Triples 2 07-23-2005 01:31 PM
