Screws for rear fender - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-18-2006, 12:58 PM   #1 (permalink)
Favourite Bike: Speed Triple - 2006
Other Motorcycle: DRZ 350 1994
Anybody have a hard time removing those 2 screws for the rear fender under the seat. Very stubborn. Is there a fastner of nut holding them on the other side?
redwhiteblue is offline   Reply With Quote
Old 07-18-2006, 01:05 PM   #2 (permalink)
Favourite Bike: Speed Triple, baby
R100Pilot's Avatar
Other Motorcycle: R100RS, 1050 Sprint
Extra Motorcycle: TT600 - Spongebob
Uh... you're talkin' about the big ugly rear fender that hangs over the rear tire, or the boat tail?
My fender removal was made much easier when in a moment of utter BRILLIANCE, I decided to actually throw a flashlight on the subject and realized they were Torx screws, not Allen. Popped on the Torx and it was easy.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
— HST
R100Pilot is offline   Reply With Quote
Old 07-18-2006, 04:05 PM   #3 (permalink)
It should be straight forward job like R100 said. took me no more than 5mins.
Something it gives for you, something it takes..
L4TUA is offline   Reply With Quote
Old 07-18-2006, 04:13 PM   #4 (permalink)
R100Pilot's Avatar
It took me 10 - the first five trying to turn an allen wrench in Torx screws. It takes a Real Man to admit something that stupid.
— HST
Old 07-18-2006, 06:58 PM   #5 (permalink)
blue loctite in mine , keep turning
HURT SMURT !!!
ctrhenry is offline   Reply With Quote
Old 07-18-2006, 07:05 PM   #6 (permalink)
Some of those fasteners back there are removable plastic rivits, similar to the ones below:
These need to be removed when wanting to delete the spade under the light.
Near the front of the seat, you can access them through the two large holes in the seat fairing. In the rear, there are some you can access by removing the bolts and then pulling on the tail light/plastic assembly to remove it down off of some retaining clips (hard to explain over the internet).
odium is offline   Reply With Quote
Old 07-18-2006, 07:07 PM   #7 (permalink)
Forgot to mention that needle nose pliers of an appropriate size will work to clamp the rivit and pop the plastic screw back up. Removable rivits sometimes aren't removable by only turning the screw in the visible side and you have to clamp the back.
Old 07-18-2006, 08:46 PM   #8 (permalink)
jimmydean's Avatar
I had no problem removing mine.............but putting them back in was the problem. I'm not talking about the fasteners but the long torque screws.
I stipped on putting it back in- hanging out by a half inch. Anyone now where to get a replacement? :hammer:
jimmydean is offline   Reply With Quote
Rear fender eliminator plan using stock sub-fender cshell Speed Triple Forum 2 01-14-2009 03:44 PM
rear fender TallGear Sprint Forum 3 02-06-2008 09:35 PM
rear fender Scardi The Rocket Science Forum 6 04-04-2007 02:21 PM
Rear Light Kit after removing rear fender TonyThruxton Club Cafe' 2 05-15-2006 09:47 AM
