ANOTHER CERAMIC COATING QUESTION - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-17-2006, 07:15 PM   #1 (permalink)
MAYBE I'AM THINKING TOO MUCH BUT IT SEEMS TO ME THAT WITH EVERYBODY SEARCHING FOR THE PERFECT AFTERMARKET EXHAUST BECAUSE THE STOCK IS TOO RESTRICTIVE, THAT POWDER COATING THE INSIDE OF THE PIPE WOULD JUST MAKE MATTERS WORSE. ANY THOUGHTS?
And you KNOW this.........MAAANNN.
itchin is offline   Reply With Quote
Old 07-17-2006, 08:46 PM   #2 (permalink)
Several issues here with what you said.
First of all, Ceramic coating is not Powder coating. It's a very thin coat much like chrome and wouldn't effect flow. FYI, Powder Coating is a polymer like plastic, and Ceramic is (as it's name implies) Ceramic.
Second, Powder coating is also pretty thinly applied, but would cause all sorts of havoc inside an exhaust pipe. It would eventually melt, flake off, and the exhaust pulses could pull pieces up into the head. Bad news!
Thirdly, the restrictions in the factory pipe are more due to the sharp bends in the header than the diameter of the pipe. A good header like Zard has very gentle bends and as few bends as possible. Also, the collector isn't optimally designed for proper flow. Finally the half system that splits the exhaust into two mufflers is extraordinarily poorly designed, with poor bends and too small pipe.
None of these problems would be solved, or made worse, by ceramic coating.
None of this applies to the factory silencers, which have a catalytic converter inside of them and are quite restrictive. There's only one way to fix that: Replacement!
crashmasterd is offline   Reply With Quote
Old 07-17-2006, 09:25 PM   #3 (permalink)
ceramic coating also reduces temps on whatever its on...
anything running cooler is going to run better
Mesoam is offline   Reply With Quote
Old 07-18-2006, 06:25 PM   #4 (permalink)
well alrighty then, good info. Thanks.
Old 07-20-2006, 12:22 PM   #5 (permalink)
how could it possibly reduce temps?
"The person who says it cannot be done should not interrupt the person doing it." - Ancient Chinese Proverb
'we are all born naked and screaming and if you're lucky that sort of thing won't stop there.' -unknown
abelard is offline   Reply With Quote
Old 07-20-2006, 01:51 PM   #6 (permalink)
The theory on that is that the ceramic coating acts as an insulator which keeps heat IN the pipes. Hot air (exhaust) flows faster than cooler air so it helps exhaust the gasses better....theoretically. They say that the coating since it insulates keeps the outside of the pipe cooler. I personally dont buy it.
Mike
bikeman is offline   Reply With Quote
Old 07-20-2006, 02:12 PM   #7 (permalink)
Sounds like a stretch! I guess if it were a poorer conducter of heat than the pipe alone that would possibly make a difference but nothing worth talking about I would imagine.
Old 07-20-2006, 10:16 PM   #8 (permalink)
I have my pipes and can ceramic coated and you can betcha it reduces heat on the outside.
xSpeed3x is offline   Reply With Quote
Old 07-21-2006, 12:31 AM   #9 (permalink)
No kidding!
do it yourself ceramic coating ctrhenry Speed Triple Forum 9 08-30-2006 12:19 PM
Ceramic coating TJRCARRILLO Club Cafe' 7 07-23-2006 08:34 AM
Ceramic coating question... Lom Speed Triple Forum 27 07-17-2006 05:07 PM
Ceramic coating vs. Powder Coating m_t_yeo Club Cafe' 13 04-04-2006 12:25 AM
Ceramic Coating question franco Twins Talk 4 07-17-2005 12:49 PM
