Probably brake line moving through one of the various mounts... no reason for the forks to squeak on compression, something metal is moving against metal. Or the T-line in the little plastic mounts on the front fender, could be the culprit...
If you are "bouncing" then it's probably your headlight assembly or instrument cluster....
Isn't that Special...
