Motorcycle.comSportbikeTrackGearShopTriumph.comMotorcycle.com Classifieds!BikeBanditRacerPartsWholesaleAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 07-15-2006   #1 (permalink)
has anyone tried to drill out the rivets and remove the baffles from the stock mufflers?? i have thought about it but haven't tried it yet.
instead of buying a new system...may save alot of money! :???:
ssregal39 is offline   Reply With Quote
Old 07-15-2006   #2 (permalink)
Getting the caps off is easy enough. Getting through the cat wont be easy. The rest of the innards are quite stout also. I would not attempt it. Keep your cans stock so you can go back.
Hotmailjerk is offline   Reply With Quote
Old 07-16-2006   #3 (permalink)
I considered this as well but I think it could lead to disaster unless your name is Pops Yoshimura.
Also it could adversly effect the mapping etc. But if it was as simple as drilling out the rivets and removing a baffle I recon it wuld have been tried.
If you attempt it good luck as you could discover the holy grail of a nice sounding cheap modification !!! :hammer:
slippery is offline   Reply With Quote
Old 07-16-2006   #4 (permalink)
Here is a link. I decided to go for TORs or wolf cans. More money, less risk and headache... Good luck!
http://www.triumphrat.net/modules.ph...22280&forum=19
Life is best with good food, good wine, and a bad woman!
maxed66 is offline   Reply With Quote
Old 07-16-2006   #5 (permalink)
A couple of guys have done this surgery with okay results. One guy (don't remember who) claimed you shouldn't even think about unless you're a good TIG welder. Of course he completely disassembled the thing, which you needn't do.
Several guys have reached in and drilled out the baffle with long drill bits and reported good results. I can't imagine but it would be easier to do if you removed the end cap.
I'm sure you would need to have the TOR map installed after doing any of this.
The good news is that removing the end caps isn't going to destroy anything, so there's no reason why you can't do a little experiment. Once the caps are off then you will see if you can go any further. I hear that it's difficult to actually get the internals out (Hence cutting the barrel and welding it back together), but if you just want to open it up to make it a little louder it might be worth it. You aren't going to realize any horsepower gains to speak of though.
crashmasterd is offline   Reply With Quote
Old 07-16-2006   #6 (permalink)
If you want loud forget it. Even between stock and TORS there is only a little difference in loudness.
The effort to disassemble gut out and re-assemble the stock cans is just not worth the effort.
Keep the stock cans for when the man in the white coat with the sound and pollution probe examines your bike.
Avi8or is offline   Reply With Quote
Old 07-16-2006   #7 (permalink)
thanks for the info gentlemen. i guess i'll leave everthing alone for right now, til i feel like spending $$$$$ on new carbon cans.
thanks
Old 07-16-2006   #8 (permalink)
I agree.. was disappointed with the tors.. too quiet for me.. get yourself a ZARD... mmmmm
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 07-16-2006   #9 (permalink)
I'm very happy with my Trident carbon fiber 1/2 pipe system. Keeps the stock muffler layout/styling. Nice deep tone, good power. I got mine without the little spigots on the outlets. Even stubbier than the pic.
[ This message was edited by: dr_gallup on 2006-07-16 14:36 ]
dr_gallup is offline   Reply With Quote
Old 07-16-2006   #10 (permalink)
My standard cans were modified by a local stainless worker.Standard cans do a few loops before they exit,what he did was basically made them straight throughs leaving the middle flap(you can see this when you look inside the hole)and made the exit pipe bigger,flaring the ends over to suit. The sound is just right i think.I noticed response was crisper even without a new tune but at my next srvice they installed a update tune(don't know what it was and it was even better response wise.
Bucket :hammer:
Bucket
BUCKET is offline   Reply With Quote
Exhaust query brian65 Daytona Deliberations 4 02-02-2008 06:51 AM
Anyone want a stock 07 exhaust? jbowen Speed Triple Forum 3 12-30-2007 08:43 PM
stock exhaust stubey Speed Triple Forum 3 09-20-2007 07:25 PM
Stock Exhaust MotoSayle Twins Technical Talk 3 03-27-2007 11:09 PM
Exhaust query simonjrwinter Trophy 2 06-01-2005 01:03 PM
