ShopTriumph.comMotorcycle.com Classifieds!SportbikeTrackGearMotorcycle.comBikeBanditRacerPartsWholesaleAdvanstarMotorcycleShowsTrident-Exhausts.com
RacerPartsWholesale
Old 07-15-2006   #1 (permalink)
I may be full of S*&T but it just occured to me that allthe popping is going on during decel. My own experience is when i'am down shifting. You shift to a lower gear, try and match the revs with the throttle( not easy to do ) and let the clutch out. The engine revs , as the revs start to slow the popping starts. So, my question is, would a slipper clutch help any or am i barking up the wrong tree? Does anybody even make one for S3. What ya think?
And you KNOW this.........MAAANNN.
itchin is offline   Reply With Quote
Old 07-15-2006   #2 (permalink)
It can be the same with any bike. When you leave the throttle open during down shift you are naturally going to get a pop of sorts. My Warrior does it. It can be a number of things. I know I play with the throttle on decel because I enjoy a good pop. If I get of the gas quicker on decel she won't pop.
xenarchi is offline   Reply With Quote
Old 07-15-2006   #3 (permalink)
From what I have read here it seems that the 1050 bikes with TORS and Tune do not pop, however the 955 bikes with TORS and Tune do pop on decel. I think that the secondary air injection system causes the popping. I think the only way to stop the popping would be to remove the air injection system. Some say the popping is from a lean condition, however Formula One cars pop on decel, and I believe those engines to be perfectly tuned.
roller is offline   Reply With Quote
Old 07-15-2006   #4 (permalink)
The S3 doesn't need a slipper clutch... it would be redundant.
For those having issues with popping... Make sure all of your joints are truly sealed... mine weren't. MAkes a difference...
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 07-15-2006   #5 (permalink)
I removed the SAI and installed a non-SAI tune. No more popping, banging, or other loud noises anymore.
popping kc dave Trophy 23 01-30-2008 11:51 PM
Popping My Bead airrider03 Sprint Forum 9 08-18-2007 12:18 PM
Popping Modifications & Workshop Talk 19 03-16-2007 01:38 AM
no more popping DannyChrist Twins Technical Talk 1 10-08-2006 12:46 PM
Popping on take off? Avatar Hinckley Classic Triples 9 09-10-2006 04:31 PM
