Hi there,
I have a MY04 S3 955 with ONLY dipped/high beam switch (and the indicator switch) in the left hand controls. (Edit: and the horn switch as well
I've seen other S3:s (MKII 02-04) that aslo has a switch controling "null/park/automatic" for the headlights, making it possible to switch off the dipped/high beams (only 5W bulbs lit). Mine only has a plastic cover where that switch is located on other (older) S3.
When did this switch dissapear? Is it compatible to replace it with the elder switch (considering cables/connectors)?
Thank you
[ This message was edited by: lillebror on 2006-07-12 02:31 ]
